how to increase boost on aem ems series 2?
I've tried to set the wg base duty map to all zero and 85 percent and the boost does not change. Anyb ideas? I have aem ems series two with aem tuner. I have mac solenoid and the wires going to pins d4 and d16 I think.
IDK if the box is any different pin out wise, but when I had my solenoid hooked up I only had one wire going to the boost solenoid from the EMS.
Mine also used to click on startup, and it was audible because it was mounted to the firewall. Have you ever heard/felt the solenoid clicking to know that it is wired correctly?
Originally Posted by riceball777,Dec 30 2010, 07:21 AM
you HAVE YOUR MAC SOLINOID wired wrong
The solinoide are 2 wires. 1 wire will go to a power source and 1 ire will for to the last pin in the D plug on the aem ems. There is only 1 wire to the ems not 2
