How much boost I should be having
Old May 13, 2013 | 04:43 AM
kaissi's Avatar
Default How much boost I should be having
I have a Vortech V2 supercharger on my AP1.
I had 550cc injectors and 4.5" pulley, and use to be making 7.6 psi
I installed 1000ccm 3.8" pulley and 4bar Map sensor
now I'm making peak exactly 10 psi
shouldn't be around 12-15?
what are the possible reasons for this low peak boost!!!!
Thank you guys in advance
Old May 13, 2013 | 06:16 AM
s2kt3's Avatar
slipping belt at high rpm ?
Old May 13, 2013 | 06:20 AM
kaissi's Avatar
how much should i expect from 3.8" pulley
Old May 13, 2013 | 06:48 AM
cariza's Avatar
I have an AP2, 4.5in pulley and make 9 psi with stock exhaust and 8 psi with aftermarket exhaust. You should be making 10 psi at least with the 4.5 since you rev 9krpms and 12-13 with the 3.8.
Sent from my Nexus 4 using Tapatalk 2
Old May 13, 2013 | 06:50 AM
kaissi's Avatar
what about BOV failure?
or it has nothing to do with boost ?
Old May 13, 2013 | 02:36 PM
kaissi's Avatar
and at like 12 psi, how many HP I should be having?
I'm still on stock exhaust,
will changing it to 70mm make a big difference?
Old May 13, 2013 | 02:55 PM
99SH's Avatar
Can you post your boost plot?
Old May 13, 2013 | 03:20 PM
myflys2k's Avatar
I'm AP1 with vortech 4.5" pulley and I see 8psi in my logs. When I was using the 5" stock pulley I saw 6psi max. I have fujitsubo exhaust with HFC. Your elevation also has a playing factor of boost pressure.
Old May 13, 2013 | 03:29 PM
kaissi's Avatar
I'm on sea level,
I'll send the plots soon
so at 4.5 I made 7.6 psi, should be normal right?
but 10.7 on 3.8" isn't it low?
how many HP should I be making by 12 psi ?
kaissi's Avatar
theoretically
