How much room between the turbo and block?
Old Aug 15, 2009 | 04:24 PM
deathsled's Avatar
Default How much room between the turbo and block?
I understand that the standard log manifold from InlinePro might possibly locate the turbo further away from the engine and closer to the car/frame than other setups which makes me think it might be best suited for an internal wastegate setup. What I really want to know is how much space is there between the compressor housing and the engine generally?
I'm interested in running an internal wastegate for various reasons. I'm wondering if there is enough room to fit the ATP "ultimate internal wastegate" with some of the smaller turbos like a gt28 or gt30 (I believe the housings on these turbos aren't TOO large).
For some good pictures of the setup look at http://www.atpturbo.com/root/releases/release103105.htm
Old Aug 15, 2009 | 05:48 PM
Envied's Avatar
If this helps, it is 4 1/8" from flange face to center of the T3 inlet flange.
Old Aug 16, 2009 | 10:17 AM
deathsled's Avatar
you mean from the flange face that bolts to the head to the center of the turbo inlet flange? Thanks! That's better than nothing!
Old Aug 16, 2009 | 11:42 AM
Envied's Avatar
Yeah, from the face that bolts to the head. I have my manifold sitting at home if you need any more dimensions, I can get them tonight. I am at work right now.
JSanford2032
Apr 8, 2019 04:40 AM
AlexSobe614
Sep 4, 2016 05:36 PM
omarisramo
Aug 24, 2012 08:20 PM
bseries_ben
Mar 24, 2009 09:24 PM
