ID 1000cc
Old Nov 26, 2009 | 10:53 AM
roi's Avatar
roi
Default ID 1000cc
Just got my ID 1000 for my AP1 (Inlinepro rail)
It did not come with the red adaptor that is in the picture, do I need it or do they fit as they are?
Thanks
Roi
Old Nov 26, 2009 | 11:34 AM
Boofster's Avatar
My 725's were bare as well. Fit just fine straight up. I reused the o-rings from the stock ones. Lots of motor oil lube
Old Nov 26, 2009 | 03:55 PM
neeman77's Avatar
The ID 1000cc do not need the little caps to fit, they are machined to fit into the s2000 fuel rail.
Old Nov 26, 2009 | 10:15 PM
roi's Avatar
roi
Thanks guys
Old Nov 27, 2009 | 09:28 AM
93turbo16's Avatar
You only need the adapters when you are working with the smaller sized injectors, like the B,H,D, etc honda engines.
The newer K and F series stuff are all the same size as the standard Bosch injector.
Old Dec 3, 2009 | 03:19 AM
roi's Avatar
roi
Just tried installing them and they do not fit
the seat that they come with is to small for the honda manifold
what am I doing wrong???
Old Dec 3, 2009 | 03:34 AM
Elroy's Avatar
There are o-rings top and bottom of the injector. Place the o-ring on the injector will a liberal amount of grease "on the o-ring". As boof said, it is going to be a bare!
J
Old Dec 3, 2009 | 12:08 PM
s2000isu's Avatar
So I am confused. I was looking at some bosch injectors and I found some for b series and some for k series. The b series injectors looked like they were a better fit then the k. Am i mixed up would k serie be what id want?
Old Dec 3, 2009 | 12:10 PM
JustinC's Avatar
no you want the ones for the S2000, I will try and post a photo of them installed when I get home today. I didn't try to force the o-ring on my injectors, I just seated them on the existing rubber pieces on the manifold and they work perfect.
Old Dec 3, 2009 | 01:40 PM
Elroy's Avatar
F series ID-1000cc
J
