ID2000 injectors idle problems
Old Sep 21, 2011 | 03:31 PM
  #41
Spoolin's Avatar
Originally Posted by penguinsintuxedos!?
nearly 1000 with maxed out injectors and 80psi fpr haha
Thats a built engine isn't it? I believe I have the record for stock engine and still living at the moment. I'm around 780 whp at 33 psi now. How in the crap did you make almost 1000 whp on only 4 more psi than I? I figured another 4 psi (37 psi) with a 6765 would probably get to around 850 whp, but my 6262 is about pooped out now at 33 psi. I may be able to squeeze another 25 whp out of it safely to get to a little over 800 whp (probably another 2-3 psi), but thats about it I think. You must be running a 42r or something then.
Old Sep 21, 2011 | 05:23 PM
  #42
DFWs2k's Avatar
I think that was with his 2.4
Old Sep 22, 2011 | 07:21 AM
  #43
penguinsintuxedos!?'s Avatar
Yup, 2.4 built from top to bottom. I believe it is the equivalent of a 42, but turbo sizes confuse me. It's the biggest BW S400 available
Old Sep 22, 2011 | 03:15 PM
  #44
Spoolin's Avatar
Ahhhhhh.......Gotcha. That makes more sense now.
Old Sep 23, 2011 | 05:55 AM
  #45
Haha, yup.
[attachment=9801:223689_10150721998210037_816220036 _19927293_4796409_n.jpg]
[attachment=9802:261823_10150701274875037_816220036 _19668065_5479878_n.jpg]
[attachment=9803SCF6014.JPG]
You hold quite an impressive record on a stock motor then, haha. It gives me confidence to push this car harder!
Attached Thumbnails ID2000 injectors idle problems-223689_10150721998210037_816220036_19927293_4796409_n.jpg   ID2000 injectors idle problems-261823_10150701274875037_816220036_19668065_5479878_n.jpg   ID2000 injectors idle problems-dscf6014.jpg
Old Sep 23, 2011 | 04:22 PM
  #46
Spoolin's Avatar
Thanks. So far so good and I plan on pushing it as far as it will go once I get the new FB Getrag trans swap in it. I'm hoping it'll make it to 900 whp with a 67 turbo and new FB twinscroll manifold. That's the next step anyway and we will see what happens.
Old Sep 25, 2011 | 10:08 AM
  #47
I'm not a big fan of the supra transmission because i've broken several of them. I would rather buy a dogbox, but neither really apeals to me. I've decided to use a TH350 and support 1000hp with ease!! Either way i'll be subscribed to see what you can do!
Old Oct 5, 2011 | 01:35 PM
  #48
DFWs2k's Avatar
Originally Posted by s2000442
Still having oscillation issues with ID 2000's and kpro. It goes away when fuel is hot but I compensate by running 1350rpm and adding fuel into ect fuel compensation table so I dont get the lean oscillation swings when warming up. Going to have induction performance look at log. You can only play with phasing in kpro slightly and its not rpm dependent unles its wot. AEM has more control so easier to tune the 2000's
Hopefully Tony can get it figured out for me...
Old Oct 5, 2011 | 01:39 PM
  #49
s2000442's Avatar
Let me know. I have been adding fuel at idle to compensate for lean oscillation. Its not bad and I have rpm set to 1050 now.
Old Oct 5, 2011 | 01:48 PM
  #50
DFWs2k's Avatar
retune date isn't till mid-november, so it'll be a little while
