if no bov on greddy's kit and increase factory bst
Old Oct 18, 2008 | 11:17 PM
asukadc's Avatar
Default if no bov on greddy's kit and increase factory bst
would it be a better idea to have it on? and also let's say you don't have it on and have it tuned for 9 psi, then when u decided to get a bov, do u have to retune?
Old Oct 18, 2008 | 11:52 PM
kix's Avatar
kix
nope... you'll be fine.
It wont hurt the turbo either, however, you'll get the compressor surge noise and iit'lll kill the spool between shifts.
Old Oct 19, 2008 | 01:48 AM
B_SoFresh's Avatar
i was always told compressor surge is a bad thing.
Old Oct 19, 2008 | 08:23 AM
jwa4378's Avatar
Compressor surge kills turbo seals. It might not happen as quickly as if you were boosting past 10-12psi (higher the PSI, the faster the blade stops on the turbine, as there is more force to resist it). It will eventually wear out the turbine seals, though, and faster than if it were not happening.
It always a good idea to run a BOV in just about any FI application. Its another safety valve, in case something else goes wrong (wastegate sticking, etc).
Personally, I would never run a turbo system without a BOV.
John
Old Oct 19, 2008 | 08:51 AM
asukadc's Avatar
where can i buy the greddy pipe with the flange on so i don't have to take it off and weld it?
Old Oct 19, 2008 | 10:31 AM
Olegator's Avatar
just buy the bov on ebay with the flange and get it welded...
Old Oct 19, 2008 | 10:59 AM
asukadc's Avatar
what about the tuning part, necessary to retune?
Old Oct 19, 2008 | 02:48 PM
jwa4378's Avatar
No tuning needed... just put it on the intake pipe, and route the vacuum line to a vacuum source... no tuning needed to install a BOV.
John
Hagar
Feb 14, 2014 07:20 PM
P'sS2k
May 8, 2008 10:13 AM
nMeOnE
Nov 23, 2007 10:03 PM
s2guru
Mar 26, 2007 09:12 PM
nsxinsac
Jun 22, 2005 05:03 PM
