Ignition Breakup? Need some brains.
Old Jul 30, 2009 | 03:36 PM
TheMidasTouch's Avatar
Default Ignition Breakup? Need some brains.
I
Old Jul 31, 2009 | 10:47 AM
S2K-F8's Avatar
I hope someone has some insight. This is my car that Mike is talking about.
I've had the Comptech kit on the car for 4+ years with no major issues. The hesitation/popping started after the K-Pro install (we also did a 12lb. pulley and ID 725cc injectors at the same time). With the added boost my IAT's were running really high (180-195 during hard pulls) so we thought that might be the issue. We ended up scrapping the Aftercooler in favor of a Front Mount (we also installed an Alaniz PnP head and a S.O.S. 3 bar Map sensor at the same time). My IAT's dropped significantly but still no change with the high RPM hesitation.
To date we have also tried:
3 different coil packs (Okada, AP1, AP2)
3 different plugs (iridium, copper)
1 other K-Pro (thanks Kevo!)
On top of that we have also tried grounding the battery to a different location in the engine bay, grounding the head, grounding the valve cover, and grounding the ECU.
We're running out of ideas so anything will help!!
Scott-
Old Jul 31, 2009 | 03:13 PM
TRBOKEV's Avatar
I had a similar problem.
It ended up being something very stupid for me..
After I pulled the comptech esm when I was supercharged I soldered the wires back together, but had a bad solder joint in the wiring (which was for the map sensor). It would surge, dump fuel and bog any time I started to go into boost, but jiggle the wires down by the foot area and it would magically go away.
Old Aug 3, 2009 | 11:31 AM
S2K-F8's Avatar
Well yesterday I checked the wires that the ESM were tapped into, stripped back the sheathing and put solder over the wires. Still no change....popping/power loss around 7000 rpm's.
Any other ideas??
Scott-
o'malley_808
Apr 1, 2019 10:46 AM
dailyap1
Jun 27, 2014 03:06 PM
SuperS2nv
Aug 13, 2012 10:54 AM
slicko9
Jul 3, 2010 09:47 AM
demonderrick
Nov 11, 2005 08:52 AM
