Injectors?
Old Aug 26, 2005 | 08:13 AM
slamar1's Avatar
Default Injectors?
Looking for best injectors (size) fo the following situation:
300 - 350 hp (<400whp)
10 lbs of boost or lower, probly 8 psi
InlinePro turbo kit with GT 35/61
Old Aug 26, 2005 | 09:16 AM
Black Nugget's Avatar
With the information you have provided I personally would recommend 750cc injectors.
Currently I am running a comptech supercharger with 3.25" pulley. On a very hot humid day she was able to make 358whp pushing 9.75psi at the motor, but my tuner said on cooler temperatures I should make another 1 - 1.5psi. He said once those numbers are hit I would be at 57psi in the AEM Fuel Pressure Regulator with Injector Duty Cycle being at approximately 84%. These numbers are using RC Engineering 650cc Injectors.
However, someone on this site may be able to correct me. My knowledge is only from Supercharged Setups. A Turbo may require a much larger injector size for obvious reasons.
Hopefully someone - such as AusS2000 will be able to comment!
Old Aug 26, 2005 | 10:50 AM
RZFD's Avatar
I'd go ahead and get 880's. You'll want more later, and if your tuner is any good you'll never know the difference.
Old Aug 27, 2005 | 08:16 AM
slamar1's Avatar
lol... I hope not (again)
750cc sound about right?
Old Aug 27, 2005 | 08:30 AM
kane.s2k's Avatar
I've got 750cc injectors for sale just FYI
see my sig
Old Aug 27, 2005 | 09:53 AM
fperra's Avatar
Me too. Kane, you beet me to it.
Old Aug 27, 2005 | 10:41 AM
slamar1's Avatar
Sold! to the lowest seller!
JK guys, I will do some lurking and get back to you
Wydget
May 28, 2011 12:27 AM
ctb2024
Oct 19, 2008 09:08 AM
macprotege5
Feb 6, 2007 04:02 PM
jbotstein1
Jun 2, 2005 02:57 PM
warpspeed2k2
Feb 27, 2003 04:15 PM
