Inline Pro 6265E Build - Mase Tuned
Originally Posted by g352s2k,Jun 4 2009, 11:06 AM
he believe he's going to throw a meth kit on there and boost up to 22+psi...... and maybe some nitrous if he doesn't get the numbers he wants. He said something about blowing up his motor buying a ap2 and giving me the turbo kit..
Originally Posted by Revenge,Jun 4 2009, 09:21 AM
Scott what are you going to boost to? Also are you going to run a meth kit, do you think it would help?
Originally Posted by dsddcd,Jun 4 2009, 04:18 PM
Yes, I will be runing an HFS6 and probably nearing 22-24 PSI baring nothing breaking. I would really like to get close to 600HP at the wheels on the high boost setting and 350-400 on the low boost.
I bet you will at least be at 500+ with all that you are planning.
Either way your attention to detail is remarkable and something we should all strive to duplicate in our FI cars.
I'll be happy with 450 when all is said and done.
Okay slowly but surly I am getting closer
Battery Relocation Done
https://www.s2ki.com/forums/index.php?showtopic=715330
Build a audio knock detector Done
Intercooler pipes halved and rerolled then trimed to fit, now I can work on the motor w/o pulling the bumper. Best of all the factory grill can be left in place for that, "All I have is Exhaust, K&N filter and Performance Chip look" Done
Tapped the manifold for the Nitrous?
Done
Wastegate studed with old manifold studs and bronze Nuts added (Lets See it Fall of Now) Done
Heat sleeved the AC lines, turbo oil feed and coolant lines Done
DoneWastegate studed with old manifold studs and bronze Nuts added (Lets See it Fall of Now) Done
Originally Posted by camuman,Jul 14 2009, 08:25 PM
man u are making progress. question, i see the sound deading in your trunk, did u have that previously? if so, did u notice lower road noise?
cant wait to see ur results.
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Keep up the good work!
