Inline Pro Kit
Old Feb 4, 2009 | 07:55 AM
Spec_Ops2087's Avatar
Originally Posted by ushyaar,Feb 4 2009, 01:50 AM
it is the plain log kit...i thought at 10 lbs without a HG it would be at about 390 so I figured with lower compression but higher boost could possibly pull off 400..
if not what would you think 12 and 20 psi would bring in rwhp on this setup?
I made 360rwhp at 10psi on stock compression for some comparison.
Old Feb 4, 2009 | 08:52 AM
TelosHedge's Avatar
with a 3mm hg @ 12 psi i would guess somewhere around 350. @ 20 psi with supporting mods and enough turbo you should be around the 450 range or higher.
Old Feb 4, 2009 | 04:57 PM
ChefJ's Avatar
IP log mani 3mm hg
388whp
287wtq
at 13.5psi
90%humidity
94 degrees.
Old Feb 4, 2009 | 06:57 PM
mv1015's Avatar
Originally Posted by ChefJ,Feb 4 2009, 05:57 PM
IP log mani 3mm hg
388whp
287wtq
at 13.5psi
90%humidity
94 degrees.
what turbo are you useing?
Old Feb 4, 2009 | 07:12 PM
ChefJ's Avatar
sc61 .63hot side
Old Feb 4, 2009 | 08:43 PM
TRBOKEV's Avatar
Any more ILP numbers?
I have an inline kit coming in soon that will replace my greddy kit.
Old Feb 5, 2009 | 08:27 PM
ushyaar's Avatar
bad news..got the call from Chris today NONE of the body kit parts would fit or mold to the car..so scrap that idea and the original pick up date of feb 13-14th. so now we are going to do a plain OEM front and rear bumper with front lip. To make the car stand out a little I'm thinking of adding a coilover kit. Chris was suggesting either Megan racing or Tein Flex...any input? I will get them to lower the car so that there is absolutely no fenderwell gap..then im sure it will settle a little more leaving the tires ever so slightly tucked.
Old Feb 5, 2009 | 08:28 PM
ushyaar's Avatar
also hopefully with a coilover kit maybe the car will have a little better chance of holding onto the road with all this new power! camber kits arent necessary for an s2000 correct?
Old Feb 5, 2009 | 11:21 PM
KaNgArOo's Avatar
No need for a camber kit. You'll have fun with the turbo kit install even if it's not more then 400whp, but I'm sure with 20 psi you'll be around 430whp at least and I mean at the least especially with the 3" exhaust system.
Old Feb 6, 2009 | 05:56 AM
dsddcd's Avatar
The boys over in the racing section are the real experts on this subject.
