Inline Pro Oil Filter relocation kit
Old Apr 16, 2009 | 10:33 PM
  #21
Sarek's Avatar
Forgive me for bringing up an older topic, I'm getting a very faint leak from my Canton block adapter also. Are you putting teflon, plumber's dope on this part of the adapter?
edit: wrong picture
Old Apr 17, 2009 | 06:46 AM
  #22
Spec_Ops2087's Avatar
Your point at the bolt that the oil filter screws into, you don't want tape on that!
Old Apr 17, 2009 | 10:33 AM
  #23
TRBOKEV's Avatar
Do you have to use the relocation kit with the inline pro log kit?
I have the inline kit with the 5965B turbo, but my relocation kit is damaged and needs to have all of the fittings replaced on it.
Old Apr 17, 2009 | 10:47 AM
  #24
dsddcd's Avatar
No, you may have to take the OC off but it will fit.
Old Apr 17, 2009 | 11:30 AM
  #25
Sarek's Avatar
i meant to point to the adapter where it's leaking
Old Apr 17, 2009 | 11:40 AM
  #26
TRBOKEV's Avatar
I might try this first then before i go and do all this relocation kit work.
Old Apr 17, 2009 | 02:34 PM
  #27
Revenge's Avatar
I have a couple of questions, do you reuse the two bolts off the motor when installing the kit or do you repurchase new ones. Also on of my lines has a small frey in it is it a big deal?
Old Apr 17, 2009 | 03:12 PM
  #28
dsddcd's Avatar
The fray is generally not a problem there hould never be more than 100PSI in the line and braded hose is rated for nearly 2000PSI from most companies.
No, you will want to purchase longer allen head cap screws to make it fit. Any Westlake/Ace will have them. I think they are a 8x1.25 and about 2.5" long from memory, Basiccly you will want to add a half inch onto the factory bolts.
Old Apr 17, 2009 | 04:53 PM
  #29
Sarek's Avatar
any comments on which part you put telfon tape/plummer's dope on? (besides the pipe fittings)
was my arrow pointing to the right place?
Old Apr 19, 2009 | 02:00 AM
  #30
Sarek's Avatar
bump for a response before I put the new adapter on...
