Inline stage 1 help
Old Sep 14, 2012 | 04:40 PM
nissfam's Avatar
Default Inline stage 1 help
Inline pro stage 1 setup... I was told no gasket is used between the wast gate and manifold... Also no gasket between the turbo and downpipe? Is this true?
Old Sep 14, 2012 | 05:17 PM
camuman's Avatar
Vband?
Old Sep 14, 2012 | 05:19 PM
TonysMI4's Avatar
Not true.. Run a gasket on both.
Its not a V-band. it should be a 38mm WG with 2 bolts that hold it down. And the turbo should have 4 bolts. Only time you would use a gasket is if it was a V-band.
Old Sep 14, 2012 | 05:27 PM
nissfam's Avatar
Yeah... No vband... Inline pro actually told me that... That's why I was confused. I need to find some gaskets
Old Sep 14, 2012 | 05:45 PM
herecomesboost's Avatar
The wastegate should at least have the fire ring installed. I would also suggest installing a gasket between the turbo and the manifold. I have a T3 gasket you can have (I went with a T4 turbo so I don't need this one). PM me your address and I'll mail it to you.
Old Sep 14, 2012 | 05:52 PM
Killer_B's Avatar
If its a 5 bolt downpipe flange then you don't need a gasket.
Old Sep 14, 2012 | 06:57 PM
nissfam's Avatar
It is a 5 bolt... Ive never heard of no gasket... That's why it threw me off!
Old Sep 14, 2012 | 06:58 PM
nissfam's Avatar
Originally Posted by herecomesboost' timestamp='[url="tel:1347673550"
1347673550[/url]' post='22013023]
[quote name='nissfam' timestamp='1347669644' post='22012921']
[/quote]
How many bolt holes on your T3 gasket... The gate does have the fire ring...
Old Sep 14, 2012 | 10:58 PM
neoleooo's Avatar
Killer_B is right. i also have a 5 bolt flange and not using a gasket and have no problems with exhaust leaks. the only problem i have is the bolts from the flange falling out from the vibration. you should use some Nord Locks. it will help a lot. or you can convert it to a v-band by welding a v-band adapter to your turbo 5 bolt flange and also for the down pipe. my friend who is a fabricator/welder has done lots of it and is going to do it for me. i'll let you know how it turns out when i get it done
Old Sep 15, 2012 | 07:25 AM
andrew@ptuning's Avatar
They are correct if both the wastegate flange, and downpipe have been machine flat. We do not run a gasket on our tC turbo kit as all of our manifolds are machined flat.
Drew. R
