InlinePRO 2.5L Turbo Motor...
Originally Posted by briggle,Jan 29 2009, 06:51 AM
I looked at this about a year ago, and talked with Ya. He informed me that a good block would be all they need, so long as it is rebuildable. I decided to go the K24A2 crank and home build route, it only cost me $2400 with sleeves, fully worked crank by Castillo's (lightened, knifed, opened up rod journals, balanced and nitrided), pistons, rods, etc... I will hopefully be putting it in this summer, I need a good FI head first.
manifold - lovefab mini me, turbo deciding between the BW 366 or S362 with 70 A/R shooting for 600whp
Sorry for the thread jack
^^ No they will not yield a 9:1 CR. The preludes had a different stroke, thus effecting the the CR. I have a slightly modified crank and combustion chamber, mine are a custom set of CP's with a negative dish on the pistons of 14cc, yielding around 9.3:1 CR. You will have to measure your CC on your head, and actual stroke combined with HG thickness etc... to get your actual CR.
Originally Posted by Chris@inlinePRO,Jan 29 2009, 02:47 PM
Spec,
All I would need is a bare block, main cap section w/ the main bolts, and thats it.
No need for a crank or pistons or etc.
hope that helps.
-chris
hope that helps.
-chris
Thanks
J
J,
Oil jets can be retained now. Turn around time is about 4-6 weeks (as long as a crank is in stock when you are ready to purchase the build ).
I would recomend going with a 88mm bore so, its smaller than a 2.5 for turbo, more meat on the sleeves
