InlinePro Built Heads
Old May 21, 2017 | 02:06 AM
LostMarine's Avatar
Default InlinePro Built Heads
Educate me. Im having them do a fresh block with all the bells and whistles, but i dont know what is really required for the head. What "stages" are you all running? My goal is just to max out the 6466 and be done ( ~850-900rwhp).
If i can do just the normal $500 valves/guides ( like my current head), why should I drop $2-3k?
Thanks
Old May 21, 2017 | 06:36 AM
umair's Avatar
There is no need for a built head on a s2000. All i would do it freshen it up and get a good intake manifold/throttle body.
Old May 21, 2017 | 08:54 AM
staylor725's Avatar
I'm running the standard size ferrea comp plus valves with ferrea bronze guides, bc dual springs, keepers, and steel retainers. Not sure of the power limit of my setup but I only plan on pushing it to 700whp, I think it should be reliable at that power level. I don't know why people are always saying no need to build the head, I know more than a few people who have dropped valves and not because ap1 retainers failed. They just break off at the bottom and trash your motor. The problem is the 5.5 mm valve stems, with your power goals I would get the over sized 6.6mm on the exhaust side. Both sides would be best but at least do the exhaust side because It will take more heat before failing.
Old May 21, 2017 | 02:32 PM
LostMarine's Avatar
so, im a newb, whats the equivalent IP "stage" of that?
Old May 21, 2017 | 04:22 PM
Mijae007's Avatar
At least stronger springs would be ideal at that power level to prevent any valve float.
Old May 21, 2017 | 07:05 PM
Spoolin's Avatar
I have the 2.5x head build much like Redstar and I believe Bales. That was recommended to me by John at IP.
Old May 21, 2017 | 08:27 PM
staylor725's Avatar
2.5x is the 6.6mm exhaust side and 5.5 intake side. 3IX is intake and exhaust 6.6mm.
InlinePRO - InlinePRO Race Spec Cylinder Heads
Old May 22, 2017 | 05:31 AM
Jaspah's Avatar
A 6466 pushes 30psi of air onto your intake valves easy, which makes it harder for the valvesprings to close them. Therefore, use upgraded springs and retainers on the intake at least.
If your valves still look pretty and shut 100%... no need to upgrade them IMO.
I just did build my head because the guides were waaaay out of spec. Read the workshop manual. The clearance between the valve and guide should only be 0.11mm max. Mine were more like 1mm+ after 100k miles. So please do check! This will lead to better valve cooling and less oil consumption.
Old Jun 3, 2017 | 10:53 AM
mys2k3's Avatar
Inline pro no longer uses the 6.6mm stem on the intake side. The only difference between the two seems to be the port and polish. I'm leaning more towards the 2.5x even though they recommended the 3IX.
S2k2490
Jul 18, 2012 09:03 AM
jaundice
Jul 12, 2010 02:25 PM
Tjs S2k
15
Oct 9, 2008 02:43 AM
Sideways
Nov 25, 2007 06:19 PM
ERL_S2000
Mar 24, 2007 08:27 PM
