inlinePRO turbo manifold welding cracked!
Old May 29, 2010 | 09:26 PM
IDONTKNOW's Avatar
I recently purchased their Stage 2 sidewinder, the welds and fabrication of the manifold APPEAR to be top notch. As for customer service I haven't dealt with them so I have no input on that topic.
Old May 29, 2010 | 09:55 PM
fatjoe10's Avatar
Was this manifold braced? I remember reading something about it needing a brace to the engine block or something to prevent cracks due to the turbo weighing down on the end.
Old May 29, 2010 | 10:53 PM
CaseyGW's Avatar
Originally Posted by D1sclaimer,May 29 2010, 09:16 PM
My experience with them has been lacking.....
Thats all I will say.
im pretty sure youre being a lot nicer than i would be. your whole stage 2 kit seems to fit like shit, and youve had to modify quite a bit.
Old May 30, 2010 | 04:00 AM
josserman's Avatar
Just send the mani to them for $150. I see them honering a mani repair over a clutch as they are two very different animals. Get your kit up and running and have fun.
Old May 30, 2010 | 05:55 AM
rob!'s Avatar
Did it crack at the wastegate flange? I know the earlier manifolds used a thinner flange and they had some issues with them. If thats the case I see no reason why they will not replace or repair it for free.
If it cracked somewhere else id hate to be a dick but it probably is install error because the manifold is rock solid even without a brace. Does the exhaust have a flex section? Is the downpipe/ exhaust and wastegate free and away from hitting anything?
Old May 30, 2010 | 10:51 AM
slappynuts's Avatar
For some reason the area around the WG seems to be very prone to cracking. I had a problem with this recently and started bracing the dump tube to the downpipe.I think this has something to do with engine harmonics and heat. I have fixed manifolds that other people have built and it doesnt seem to be a weld issue. The material can crack.
Old May 30, 2010 | 11:33 AM
DFWs2k's Avatar
does the exhaust have to have a flex section?
Old May 30, 2010 | 12:29 PM
boostedf22c's Avatar
If you don't want stuff to crack you do. Unless the motor is solid mounted, or on a motor plate.
Old May 30, 2010 | 01:45 PM
freshs2k's Avatar
I had a dp crack on me before I put a flex pipe and torque dampner on my old setup
Old May 30, 2010 | 03:15 PM
Ian300D's Avatar
Where it cracked and pics of the rest of the setup is what I want to see.
