Install Complete But It Doesn't Run Right
Old Jul 15, 2005 | 05:17 PM
  #31
Slows2k's Avatar
That's WAY low fuel pressure. Either the pump is faulty, or the FMU doesn't have any restriction in it.
I'd swap back to the stock Regulator, then check the pressure again. If the pressure comes up to 40-50psi, the problem is the FMU. If the pressure is still low, it's the pump.
Old Jul 15, 2005 | 05:49 PM
  #32
folex187's Avatar
I pinched the return line and I armed the fuel pump. Pressure shot up to 100psi and I shut it off. This means the FPR is bad correct?
Old Jul 15, 2005 | 06:17 PM
  #33
folex187's Avatar
Problem solved! What should my idle and load fuel pressures be?
Old Jul 15, 2005 | 08:16 PM
  #34
Slows2k's Avatar
Give Comptech a call, I don't know the acceptable #'s for their FMU.
refect
Dec 9, 2019 03:03 PM
Pimpo
Oct 31, 2016 05:21 AM
Tjs S2k
Nov 15, 2008 07:29 AM
duff0000
Mar 22, 2006 08:56 AM
ksalik
Jul 5, 2003 02:38 AM
