installing 3mm head gasket. new studs?
Old Nov 8, 2008 | 07:13 PM
EK9MAX's Avatar
Default installing 3mm head gasket. new studs?
When instlaling a 3mm headgasket.... should i use....
1)old headstuds, because they are"stretched" already?
2)new OEM
3) ARP
I'm going to be around 12-15psi.
Old Nov 8, 2008 | 07:56 PM
TelosHedge's Avatar
from what i am told you do not need to 'retorque' new head studs if they are installed correctly.
many people have had issues with the ARP bolts but i dont know off hand.
it seems most people recommend new OEM studs, but of course YMMV.
Old Nov 8, 2008 | 09:25 PM
buzz944's Avatar
i see more ppl use the OEM over the ARP, but still some use it without any problem.
im getting th IP HG also & i dont know what i'll use...
Old Nov 8, 2008 | 09:35 PM
John_Z's Avatar
I would use new oem head bolts.
Old Nov 8, 2008 | 11:20 PM
EK9MAX's Avatar
and if I go with new oem...... Do I gotta retorque them after a certain number of miles???
Can I get at them by just taking the valve cover off?? Or do I have to take the cams and all that off again?
Old Nov 9, 2008 | 12:59 AM
S2oooNvegas's Avatar
Use new, and no you dont need to retorque.
They are insane. if you reuse your old OEM, you do 22 ft lbs, and 2 90 degree turns.
with new bolts... 22 ft lbs, and 3 90 degree turns...
That is right about 100-120 ft lbs. oem FTMFW.
Old Nov 9, 2008 | 02:17 AM
buzz944's Avatar
posted by Ya from InlinePRO back in May 2007:
New Headbolts are NOT required as long as the threads on the previous bolts are not damaged.
ARP headstuds are a good idea but are NOT required to run our headgasket. If you frequently remove the R&R the head, then ARP studs are great as they reduce the chance of damaging the head.
Torque procedure are the same as the OEM manual with stock headbolts. Nothing is changed.
Torque specs on ARP bolts are according to the ARP specs depending on which lube is used.
Old Nov 9, 2008 | 06:25 AM
EK9MAX's Avatar
Really? I don't have to retorque new oem bolts if i go that way??
what lube do i use with that?
And does anybody have the proper sequence so i don't warmp my head?
Old Nov 9, 2008 | 06:47 AM
SgtB's Avatar
The OEM head bolts are not torque to yield. If they where installed right the first time they did not stretch. Clean the threads good before you install them.
Old Nov 9, 2008 | 07:06 AM
EK9MAX's Avatar
i would assume they were installed right the first time since the motor has never been touched or modded.....
so i just reuse them in the proper sequence to 22ft/lbs and 2 90 degree turns. right?
Now I just need to know the sequence and the proper lube....
