installing 3mm head gasket. new studs?
Old Nov 9, 2008 | 08:31 AM
SgtB's Avatar
Get a helms. It is the bible. The proper lube with oem is motor oil.
Old Nov 9, 2008 | 12:16 PM
S2oooNvegas's Avatar
Originally Posted by SgtB,Nov 9 2008, 08:47 AM
The OEM head bolts are not torque to yield. If they where installed right the first time they did not stretch. Clean the threads good before you install them.
uhm, anytime you have a low fixed torque spec, and then subsequent "degree" turns, the bolt is a TTY.
The factory head bolts are TTY. thats why honda says use 22 then 2- 1/4 turns, if the bolt has been used once. if new, 3- 1/4 turns. that bolt is being stretched during those 1/4 turns.
The stock bolts have a better expansion rate than do the arp studs. while i like arp studs, and put them on everything, this engine doesnt seem to like them. (not my experience) ive seen several others with odd results. I have to assume operator error during install, but just in case, ive stayed clear of them in my s2k engines.
Old Nov 9, 2008 | 02:38 PM
passmans2kny's Avatar
i would use arps
Old Nov 9, 2008 | 03:55 PM
SgtB's Avatar
Well hell. That's what I get for thinking. on S2000 bolts. I've done so many honda heads that I didn't even think about it. My bad.
Old Dec 29, 2008 | 09:18 AM
buzz944's Avatar
rrounds
Jun 28, 2018 09:12 AM
donaldmejr
Sep 30, 2014 05:38 AM
RedLineS2k10
Mar 21, 2010 10:49 PM
afwfjustin
Mar 27, 2007 07:37 PM
S2KB00ST
Dec 15, 2006 07:22 PM
