installing arp headstuds w/o removing head
well, the topic title pretty much says it all, but do u think it would be ok to install arp headstuds just by removing the valve cover and cams and installing them while the head is still on the block? i would definitely remove the oem head bolts in quarter-turn increments as to avoid warping the head.
thanks
thanks
It would probably be ok to do that if you remove one at a time in the same sequence as the manual states to torque. What i mean is, pull the first bolt that is supposed to be torqued first and put the stud in ad retorque it. Go one at a time all the way until the last one is done. I dont know for sure if its ok to do this but i would think it would be the best and safest to keep from breaking the seal.
If you remove them all in sequence, then re-install in the correct sequence, that would be best. I would only be worried about the Honda Bond that is around the timing chain case breaking, or any of the studs not getting seated properly...
John
