installing arp headstuds w/o removing head
Old Aug 28, 2009 | 06:05 PM
Bigeggroll's Avatar
Default installing arp headstuds w/o removing head
well, the topic title pretty much says it all, but do u think it would be ok to install arp headstuds just by removing the valve cover and cams and installing them while the head is still on the block? i would definitely remove the oem head bolts in quarter-turn increments as to avoid warping the head.
thanks
Old Aug 28, 2009 | 06:22 PM
Enthralled's Avatar
what whp are you looking for?
Old Aug 28, 2009 | 06:40 PM
juntuned's Avatar
why do u want arp headstuds?... Is there a problem with your OEM ones?
Old Aug 28, 2009 | 07:23 PM
TRBOKEV's Avatar
OEM are just fine.....
Old Aug 28, 2009 | 08:24 PM
Bigeggroll's Avatar
380whp on dynojet, stock headgasket but with race gas. but it's a ctsc not a turbo so cylinder pressures won't be that bad.
Old Aug 28, 2009 | 08:41 PM
Spoolin's Avatar
It would probably be ok to do that if you remove one at a time in the same sequence as the manual states to torque. What i mean is, pull the first bolt that is supposed to be torqued first and put the stud in ad retorque it. Go one at a time all the way until the last one is done. I dont know for sure if its ok to do this but i would think it would be the best and safest to keep from breaking the seal.
Old Aug 28, 2009 | 10:15 PM
neeman77's Avatar
This thread doesnt make any sense. There is no point in going to the ARP's and there is no difference in cylinder pressure with a turbo vs a supercharger at the same boost level.
Old Aug 29, 2009 | 04:55 AM
jwa4378's Avatar
This is not the safest way to do it. Doing it this way, you are effectively removing each bolt out of sequence (after the first), as the one before is being re-torqued. Each bolt effectively becomes the first bolt in the sequence, which is not correct.
If you remove them all in sequence, then re-install in the correct sequence, that would be best. I would only be worried about the Honda Bond that is around the timing chain case breaking, or any of the studs not getting seated properly...
John
Old Aug 29, 2009 | 12:13 PM
AndyFloyd's Avatar
people make 700whp on stock headbolts.....so why again do you want this?
Old Aug 29, 2009 | 01:04 PM
neeman77's Avatar
Agreed, I am using oem bolts at 616 whp and 29 psi lol.
