installing arp headstuds w/o removing head
Old Aug 29, 2009 | 02:20 PM
berlinas2k2's Avatar
If its not broke, don't fix it.
Old Aug 29, 2009 | 04:22 PM
Bigeggroll's Avatar
Originally Posted by neeman77,Aug 28 2009, 10:15 PM
This thread doesnt make any sense. There is no point in going to the ARP's and there is no difference in cylinder pressure with a turbo vs a supercharger at the same boost level.
hmmm well, i always thought cylinder pressures were theoretically highest @ peak torque not @ peak horsepower. usually centrifugal superchargers don't produce high torque figures like turbos do, because they produce peak boost when volumetric efficiency has already begun to decrease hence less cyl pressures....... i was only considering it because i remember along time ago Cody Loveland from lovefab posted about the possible necessity of head studs, but like i said that was a long time ago.
either way i appreciate all ur guy's help! oem it is!
OEM are just fine.....
haha don't worry i knew wut u meant when u typed OWN
Old Aug 29, 2009 | 04:43 PM
s2k dre's Avatar
Keep the oem ones. And dont open the motor if it runs fine.
Old Aug 29, 2009 | 05:02 PM
AusS2000's Avatar
I have ARP head bolts. But like the others said, if it ain't broke don't fix it. You're just asking for issues.
Old Aug 30, 2009 | 05:59 AM
m R g S r's Avatar
the stock bolts are thicker than most other honda head bolts. My motor was apart, so i threw in some ARP's. If you are changing the HG you might as well install them. If the motor is fine, leave it alone.
Old Aug 30, 2009 | 08:41 AM
Bigeggroll's Avatar
thanks for the input guys!
AutoXJeff
May 4, 2017 02:16 PM
donaldmejr
Sep 30, 2014 05:38 AM
JuicedS2K
Jun 1, 2010 07:29 PM
BoostNhigh
Jul 10, 2009 05:18 AM
afwfjustin
Mar 27, 2007 07:37 PM
