installing supercharger this weekend
Old Jul 12, 2005 | 03:06 PM
s2kayo's Avatar
Default installing supercharger this weekend
I am finaly installing my comptech supercharger kit with after cooler. Any helpfull tips, hits, let me have them. thanks alot
Old Jul 12, 2005 | 03:29 PM
Sideways's Avatar
Do the crank pulley first. https://www.s2ki.com/forums/index.php?showtopic=304789
Old Jul 12, 2005 | 05:08 PM
Ztec's Avatar
Do yourself a favor and Take out your front seat before crawling on your back and SOLDERING in your ESM, try not to use the clips provided by comptech - Mine were loose and my car ran funny at first till I figured it out and soldered Be careful and have fun - It is a blast to fire it up and hear that whine
I actually found out the Supercharger install was the easy part, The ESM and the Fuel Pump were a Pain in the Ass but doable!
Get your A/F checked to make sure you are running safe!
Old Jul 12, 2005 | 05:48 PM
gfacter's Avatar
Open up the holes on the FPR bracket a little (the piece that attaches to the fender) , it will be much easier to mount.
Old Jul 12, 2005 | 07:12 PM
SIIK2NR's Avatar
With or without aftercooler?
Crank pulley......if you don't have to right tools....don't try it. Use 2, 1/2 inch breaker bars and a 2, 4' extensions and a deep socket 19mm.... makes removal a piece of cake. Set the damper with the pulley so you "push" up instead of "pull" down to break the crank bolt free, this eliminates the danger of injuring yourself or your fenders.
Careful torquing down your 10mm bolts to the Vtec solenoid....
Make sure all your sensors are plugged back in and all your vaccum hoses are routed correctly.
Old Jul 13, 2005 | 10:34 AM
s2kayo's Avatar
thanks alot
myflys2k
Southern Ontario For Sale
25
May 25, 2010 06:51 AM
s2konroids
Mar 30, 2010 10:34 PM
ABCVTEC
48
Oct 27, 2008 07:15 PM
ABCVTEC
Socal Swap Meet
78
Oct 20, 2008 10:35 AM
LonS2k
Sep 27, 2005 08:00 AM
