IP stage 2 progress and help thread
Old May 10, 2010 | 11:54 PM
DFWs2k's Avatar
Originally Posted by Spoolin,May 11 2010, 01:33 AM
Dont forget to change the old 2 hole oil squirters to the new 4 hole squirters for the pistons.
Make sure to get the oil feed on the turbo at exactly 12 o'clock and then you can loosen the turbine and compressor housings and turn them to where they need to be.
You are definitely going to have to get a filter relocation kit with the manifold. Go with Ultimate Racing's kit since it comes with -8 or 1/2" ID lines. IP uses -10 lines and I think thats too big and will lower your oil pressure.
rob! said he ran it with filter in stock location, but had to remove the oil cooler, i just got the UR kit, it still uses the oil cooler
Old May 10, 2010 | 11:57 PM
Spoolin's Avatar
^^I would think the filter would be too close to the manifold and contribute to heating the oil up, not to mention no oil cooler at all not helping the deal. I have the UR relocation kit so I know it uses the stock cooler.
Old May 11, 2010 | 12:49 AM
DFWs2k's Avatar
lol, i was just posting all the pertinent information i could think of concerning it
Old May 11, 2010 | 04:59 AM
GpWaP1 s2k's Avatar
With E85 you should be able to hit over 500hp. If only you were in KC a couple of us could give you hand.
Old May 11, 2010 | 06:55 AM
dsddcd's Avatar
Lower the oil pressure, who told you that? You have to minimize the oil pressure drop through the lines, ie bigger is better.
That is analogous to saying installing a 2" cooper feed line to your bathroom of 3/8" will drop the water pressure. Or if you are an electronics guy, replacing a piece of 10 gauge wire with 4 gauge wire will lower the voltage.
Old May 11, 2010 | 07:09 AM
camuman's Avatar
that is a serious turbo, mani, and fuel setup.
Old May 11, 2010 | 07:26 AM
Irishflame27's Avatar
this build is full of WIN, keep it up man this thing will be a monster!
Old May 11, 2010 | 08:20 AM
GpWaP1 s2k's Avatar
I cant wait to see this thing in person in about a month.
Old May 11, 2010 | 09:09 AM
D1sclaimer's Avatar
Thanks for all of the kind words everyone. I really need to get the ball rolling on this.
Old May 11, 2010 | 10:02 AM
IH8GRN's Avatar
Great looking turbo setup!!! I have the same setup, I need to install. I c you got the serated wheel....looks awesome!
