Just another ptuning build thread
Old Jan 15, 2014 | 10:39 AM
  #91
indi00's Avatar
Originally Posted by jimreaper
The instructions say "Replace the 20 amp radiator fan fuse with the supplied 30 amp fuse. (The High Performance SPAL fan will draw a little over 20 amps)". Did something change? My kit came with a 20 amp fuse not 30.
Currently using this. It is more reliable. http://www.amazon.com/Bussmann-BP-CB...+40amp+breaker
The fuse holder that came with the relay melted after a year. To much resistance and overheated over time.
Old Jan 18, 2014 | 10:48 AM
  #92
jimreaper's Avatar
Can someone explain what I need to pug into these vac lines ???
Old Jan 18, 2014 | 11:00 AM
  #93
BBBS2K's Avatar
https://www.s2ki.com/s2000/topic/788...page__st__1714
Connect the BOV to one of the brass barb on the vacuum block and the other brass barb to a vacuum source on the intake manifold.
Old Jan 18, 2014 | 03:25 PM
  #94
jimreaper's Avatar
I feel retarded after reading that. Sorry and thanks.
Old Jan 19, 2014 | 10:08 AM
  #95
jimreaper's Avatar
We are trying to start it and it just turns over. Will not start. Fuel pump is working. Any suggestions on how to find the root?
The injectors don't seem to be opening.
Old Jan 19, 2014 | 10:55 AM
  #96
herecomesboost's Avatar
Nice progress
Old Jan 19, 2014 | 03:08 PM
  #97
jimreaper's Avatar
Car won't start. I think it's because ptune map is for 1000cc injectors and I'm using 725cc. At least I hope that's it. Anyone know how to adjust the map? Or should I wait for ptune?
Old Jan 19, 2014 | 03:28 PM
  #98
You can rescale the fuel injector size/flow. Click 'Wizards-->Configure Injector Flow/Pressure' and rescale accordingly. Also, you will need to adjust your battery offset table (table is located in the 'Trims' tab). Which injectors are you using, specifically?
Old Jan 19, 2014 | 04:35 PM
  #99
jimreaper's Avatar
Id725
Old Jan 19, 2014 | 04:48 PM
  #100
Your current Battery Offset (meant for id-1k's I would presume) should have the following numbers:
You'll need to change the Battery Offset table to the following (for the id-725's):
The 1000's list the deadtimes in microsecs, while the 725's are listed in milliseconds (1 millisecond = 1000 microseconds). I'm assuming you're running factory base fuel pressure? (43.5psi)
