Just another ptuning build thread
This weekend I made some progress with a few issues slowing us down. Mounted radiator. 60 min. Mounted and wired fan. 45 min. Fuel pump. (Thanks josh dc2-2-ap1) 60 min. Turbo coolant lines. 10 min. Pan oil feed. 40 min. Installed new studs. ( ordered from jjautowerks thanks Bernard for the delivery) 30 min Mounted the manifold and fit the turbo. ( thanks ray redline s2k) 60 min. Removed the turbo. 2 issues. The manifold would not fit over the new studs. We had to carefully drill the 2 outer holes to get it to fit. The second issue was the tblock and fitting issue. I'm using Russell's thread seal on the tblock fittings. I'm hoping this is ok.
Attatched the oil line and coolant lines to the turbo. Mounted the turbo. Prepped and mounted the waste gate. Wired the oil pump. ( I'm unsure about 2 of the wires need to email ptune. ). 3 hrs.
