Kit has finally been completed.
So what kind of parts am I missing besides the fuel pump and couplers/clamps, feed line etc. Looking at the parts list it shows a million little parts like washers and bolts and screws and stuff.
Can I just buy a fuel pump by itself? Or do I need to buy the whole Vortech fuel pump kit that looks like it comes with wiring and stuff?
What sort of bolts are needed to bolt the whole bracket assembly to the engine? Or are those on the bracket or engine already?
So that is definitely the oil return line?
I am getting banjo bolts put in since I have an '01 so they are going to tap my oil pan then too. Thanks though!
Ok cool. I'll check out that site.
I think I only need like 3 couplers and 6 t clamps or so.
Hopefully by the time I piece together the parts I'll get money from usps for the broken parts.
you only need 2 couplers, one from charger to cooler then another from cooler to throttle body and t clamps for them. and yes 100% that is the return line, the feed line is a lot smaller. and has screws on both ends.
Ok cool.
So it's looking like I need the couplers and clamps, I think I will need 3 since I need a coupler coming off the sc inlet no? Gonna either do a custom intake set up or just attach a filter directly onto the sc.
So couplers, clamps, oil feed line, fuel pump, bolts for attaching the sc bracket to engine, tensioner bolt, then vacuum lines and fuel lines for the fmu. Need a breather piece for bypass valve, and a gasket for it or just use gasket maker probably.
Anyone know if I need special bolts for attaching the heat exchanger or the fmu or anything?
Oh and thanks a ton to Rain H8R for meeting up and helping me out understanding more of the set up. BIG help!
So if anyone can tell more that is needed please add it or if I forgot something already mentioned as I am tired haha.
Ok so trying to work on completing the whole bracket assembly to be able to be bolted up first.
Is anyone familiar with the parts on this list? I have the whole bracket together obviously so only need to purchase the bolts and washers and all to bolt to the engine. I know I need some spacers and all but also need the bolts to bolt on the engine anyone know for sure which one they are and if any washers or anything are needed along with it or other parts?
http://www.superchargersonline.com/product...ber=V4HS111-021
Oh and also which belts do I need in all?
you belt depends on what pully you have on the back of the charger.... you can search that there is a big thread in the fi fourm. as for the bolts look at the instructions, read them not just the parts list it will tell you what bolts go in and where. it give you size length and pitch of threads. that is how i did it. then took my list to my local hardware store and got all of them. you will prob miss one or two but you can grab them as you do the install.
Ok yeah I guess going to be a really tedious project finding the sizes and all haha.
I saw someone selling a Vortech sc kit in the fs section where all the parts are bagged and labeled. I pm'd him but no response. Would really since all the parts were removed and labeled for where they go and all.
From looking at the parts he has it does not look like it will be that bad really but who knows.
