Kpro launch control/full throttle shift
Old Feb 3, 2011 | 07:44 PM
J-GO's Avatar
Default Kpro launch control/full throttle shift
I want to set up my launch control and full throttle shift to run off the e22 brake switch pin out. Will this effect my brakes/brake lights in anyway? I assume that my cruise control will not be able disabled my pressing the brake pedal, but the car does not have cruise control anymore anyway. Are there any other side effects of using the e22 pin out? The car is still a street car.
Old Feb 4, 2011 | 06:58 AM
spectacle's Avatar
I'm confused. Why would you run the brake switch for full throttle shift?
Old Feb 4, 2011 | 07:17 AM
siadam's Avatar
Yea, I'm with Spec, thats crazy, unless I'm missing something.
Launch control/2 step is set on mph, anything less than 5mph & above 4500 rpms for example it engages. No need for a switch/etc.
For FTS, you can use your clutch interlock thats already there. I've never set it up myself, but I've seen alot of honda guys do it that way.
Old Feb 4, 2011 | 01:13 PM
J-GO's Avatar
Im talking about the actual pin out on the ece. Not the actual switch itself i have that covered. Is the e22 pin out of the ecu actually controlling anything that has to do with the brake system when using kpro on the s2000.
My other options are e26 power steering pressure switch, e29 service connector switch or b9 vtec pressure switch.
Old Feb 5, 2011 | 06:40 PM
Topillogic's Avatar
I have high/low boost toggle on E22. Everything works as normal.
Old Feb 6, 2011 | 06:28 AM
spectacle's Avatar
I would use the vtec switch since its not need with kpro
Bloody Hatch
Dec 13, 2012 12:48 PM
rmaloy
Oct 5, 2011 10:03 AM
dsthez
Dec 1, 2009 11:47 PM
jonomo
Mar 26, 2007 10:38 PM
lvs2k
Sep 29, 2001 09:26 AM
