krank vents AND oil catch can?
Currently running krank vents utilizing only the 3/8 krank vent in-line from valve cover>intake manifold and venting the front most port to atmosphere.
Link to krankvents:
http://www.et-performance.com/automotive.html
Wanting to add a catch can to the loop, something like this:
http://shop.moddiction.com/AB-Speed-...-combo-016.htm
Would I be better off running both krankvents to the catch can? Or do I omit the krankvents or only run 1 of the 2? This is on boost turbo setup if that matters. Thanks!
Link to krankvents:
Thanks for the response, redboost
Should i still try to utilize the krankvents in the system for a catch can though? Not sure if they're needed to help prevent pressure from entering the valve covers.
They are superfluous given that you're venting to the atmosphere (as opposed to the intake manifold). Just cap the nipple on the manifold.
I would skip the larger crank vent and run straight to the catch can and then vent to atmosphere. That is my setup. Essentially just adding the catch can to what you have now.
