Oil in Turbo inlet
Every now and then I inspect my turbo for shaft play/etc and every time I check there is oil in the housing. I am currently running an AP2 valve cover with the stock PCV routed to the intake manifold and the breather on the valve cover has a hose that is just vented to atmosphere.
I plan on deleting the PCV all together with this, www.summitracing.com/parts/RUS-670491/, and just routing a hose from there and the breather to a baffled catch can w/ a filter. Will this setup resolve/help my issue?
Any info is appreciated. Thanks!
either the seals are going or your drain is backing up some how.
