KW High Boost
Old Oct 5, 2008 | 09:47 PM
azride1983's Avatar
Default KW High Boost
i have a 2007 s2000. i have it for about 8 mnths already. i'm just wondering if i change the clutch to ACT can i just change the Pressure Plate and use the old oem disc and flywheel when going to KW High boost kit? or is it really recommended to change it to a new oem disc and flywheel? thanks in advance.
Old Oct 5, 2008 | 09:54 PM
s.hasan546's Avatar
i wouldnt get the act pp. you should get a clutch that holds the power not the pressure plate. get an aftermarket clutch like clutch masters or competition clutch stage 3
Old Oct 5, 2008 | 10:14 PM
fatjoe10's Avatar
The CC stage 3 is an excellent choice. It drives in a very stockish fashion, and is good for up to 500WHP. I had it in my turbo S and the clutch was very friendly on the street.
Old Oct 6, 2008 | 02:58 AM
Elroy's Avatar
Yes again on the CC stage 3. The clutch has the same feel as the stock after break-in. If you are going to the expense and time of removing the trans, replace it all while you have it opened up. I also used a new stock disk, bearing and a new 9lb flywheel. If I had to do it again I would probably go with an AP1 flywheel. Also, remove the cdv.
J
Old Oct 6, 2008 | 07:34 AM
RichV's Avatar
Why would you chose the AP1 flywheel over a 9lb flywheel? Just curious. Isn't the AP1 flywheel like 13lbs or something like that. Would it just be the difference in cost that would make the AP1 flywheel better?
Old Oct 6, 2008 | 01:56 PM
s.hasan546's Avatar
well sometimes the lightest flywheel possible isn't the best. revs drop to quick with a 9lb flywheel
Old Oct 6, 2008 | 01:59 PM
Spoolin's Avatar
More rotating mass = more low end torque.
Old Oct 6, 2008 | 02:08 PM
Elroy's Avatar
Going from 22lbs to 9lbs is NICE for rev-ups and the parasitic load from the sc but like s.hasan546 states, revs drop like a rock and just normal driving takes some time to learn how to make it smooth again. The AP1 fw is lighter than the AP2 sled wheel but probably more gracious when it comes to normal or mild spirited driving; price is probably the same.
J
Define198
May 27, 2016 01:37 AM
silvermonster
May 28, 2014 04:03 PM
Aznous
Inland Empire S2000 Owners
17
Dec 4, 2008 09:16 PM
leo520
Jul 19, 2008 03:39 AM
jaehoppa
Jul 23, 2007 11:24 PM
