Leaky catch can lines
Old Apr 6, 2012 | 12:53 AM
jpetch05's Avatar
Default Leaky catch can lines
Hey guys, I got lines and fittings from full blown this past winter, and I have them looked up tothe left side of my valve cover. I have a vented hood and I can see smoke every so often from the AN fitting leaking oil onto my manifold. Same with it leaking down the side of my catch can.
Now. It's not leaking from the hose, but leaks from where the fitting attaches to the cover and the catch can. I have used high temp Teflon tape, and cranked the hell out of the fitting to the point of where the hose is starting to twist and it still leaks.
It leaks right between the fitting "nut" and the small metal tube leading to the hose. Not between the nut and the valve cover. only on the 45 degree ones.
I think at this point it's time to buy new fittings ? Maybe not maybe so ?
Old Apr 6, 2012 | 01:22 AM
Leviisbigred's Avatar
DO NOT use Teflon tape or anything on AN fittings
Old Apr 6, 2012 | 01:27 AM
jpetch05's Avatar
After leaking for 2 weeks I used a 550 degree rated Teflon tape. Why not haha ?
And it still didn't work
Old Apr 6, 2012 | 01:40 AM
AN fittings seal on there own. maybe put more Torque on them? .. is it the back side or the side with the flare?
maybe some pics so we can help you out.. i make my own hoses with AN fittings, havint had one leak yet
Old Apr 6, 2012 | 02:29 AM
jpetch05's Avatar
They didnt seal for the first 2 weeks. And I torqued the death out of them. Like to the point of tightening them more every day to the point of putting all my weight on the wrench.
Yes its by the flange. Not the hose.
Old Apr 6, 2012 | 02:53 AM
take some pics with them on and take them off for some pics
Old Apr 6, 2012 | 04:16 AM
spectacle's Avatar
Left side as in passenger side?
Old Apr 6, 2012 | 06:51 AM
herecomesboost's Avatar
Are your AN fittings aluminum or steel?
Old Apr 6, 2012 | 07:48 AM
passmans2kny's Avatar
im not too crazy about fbm fittings, i had several leak, they replaced them but still that shouldnt be happening, but i wanted that purple lol
Old Apr 6, 2012 | 08:07 AM
3en's Avatar
3en
On my oil pan I had a -10 bung welded on. The oil pan was dropped and the an fitting was dented in a little and wouldnt seal. I used some Hondabond on the mating surface and it sealed just fine with no issues.
