Be leery of stock AP1 retainers
The Valve Keeper Remover & Installer tool looks nice! Wish I had that tool when I changed my retainers.
Used this tool and it sucked!
Had to grind it down to fit onto the spring, then took me 1-2hrs figuring the best way to compress the spring. Lost a keeper to one of the oil drain holes. Found it later in the oil pan when I did my jet bolts.
Nice write up!
Had to grind it down to fit onto the spring, then took me 1-2hrs figuring the best way to compress the spring. Lost a keeper to one of the oil drain holes. Found it later in the oil pan when I did my jet bolts. Nice write up!
I believe Billman250 (sp?) has also posted information regarding adverse effects of using ap2 retainers on the exaust valves - something about their extra weight causing issues at high-rpms...
So, just wondering, once you put new springs and retainers in and adjust everything, do you need to go back and readjust later? I am having my BC Dual Springs installed with TI retainers monday and was wondering if they had a "break in" period where they would then require another valve adjustment etc. thanks for info!
Sent using free Tapatalk - Android FTW
