Left cam position sensor A unplugged by mistake, inputs
Old Mar 30, 2016 | 01:36 PM
S2KCHRIS305's Avatar
Default Left cam position sensor A unplugged by mistake, inputs
Like the title stated I accidentally left the cam position sensor A unplugged (passenger side on valve cover) and started the car, it started up normal, once I noticed it was unplugged I turned off the engine and plugged it back in. Could this have caused any damage?
Old Mar 30, 2016 | 07:10 PM
RacerXI's Avatar
Were the cams removed or timing possibly misaligned?
Old Mar 30, 2016 | 08:12 PM
braeden's Avatar
The ECU probably would have panicked in regards to timing and thrown a CEL, but if you didn't drive it then you're probably fine, so long as you're not hearing any bad noises. We've had a faulty crank position sensor on a K24 and it throws a CEL, but I guess it hasn't done any damage because the car survived the dyno
Old Mar 31, 2016 | 06:36 AM
Chance S2K's Avatar
If you just idled the car then you're fine.
You'd just get a misfire if you had actually driven the car, as ignition timing would be off by the ECU. Would have been a problem if you had ran the car hard afterwards or left it unplugged for a long time, but definitely no harm if you just idled it.
Old Apr 1, 2016 | 07:07 PM
Thanks for the reply guys, yea the car was only idling.
Pacman123
Oct 5, 2016 06:01 PM
Deliverance
Aug 4, 2010 07:17 PM
Fredster
Sep 15, 2009 05:13 PM
kinetica
Sep 12, 2006 06:40 PM
cyk
Feb 27, 2002 10:52 AM
