Lime rock park kraftwerks ..
Old Jun 7, 2016 | 06:21 PM
chefs2000's Avatar
Originally Posted by camuman
213 is fine for water temp. Remember stock the car wont say it's beginning to overheat until 230. That's when the stock temp Guage starts to move from normal.
mine starts to move from normal at about 212.. And i was told back off at 210 .. ??
Old Jun 8, 2016 | 12:48 PM
geekyjerry's Avatar
Great video.
Inline pro has stated that it is "normal" for it to go up to 220 degrees Fahrenheit.
Old Jun 8, 2016 | 12:55 PM
camuman's Avatar
its a common misconception over what is considered overheating. This is exactly why most car manufactured make the water temp gauge sit at the same spot for a 50 degree range. in the s2k, 180-230 it stays at what we all consider normal and starts to rise above 230. now, i can say that in my SRT it does not do the range, what the temp is the gauge reads, so it moves around all day. this doesnt mean the car is overheating. read this thread, first guy even says he sees 215-220 on an autocross!!!!!!
https://www.s2ki.com/s2000/topic/978...temp-readings/
Old Jun 9, 2016 | 11:38 AM
chefs2000's Avatar
My temp sensor is located in the upper radiator tube .. I have and ap2 normal is 8 bars I believe .. It's on 8 bars from about 125 degrees till 212 about . The. Starts to move up to half lit gauge on dash .. Somewhere someone's numbers are off .. 210 and 230 it's a huge jump.. 210 sounds about right if my oem guage moves at 212
Old Jun 9, 2016 | 11:47 AM
camuman's Avatar
my apologies, its 180-225. Seriously, 212 is not bad. http://www.modifry.com/index.php?rou...product_id=157 look at the manual. stock ap2 gauge is programmed to stay on the same light from 180-225. the modifry fix for aem update changes the gauge to 180-205.
Old Jun 9, 2016 | 06:12 PM
chefs2000's Avatar
Ok thanks for that info .. So if I have aem and Dident buy the fix .. I am reading the top guage on the ap2 picture ? So if it moved past the normal 8 bar then it's over 225 ?
Old Jun 10, 2016 | 04:37 AM
camuman's Avatar
If you had oem ecu, it def would be. BUT, In this case, it could be. I am not sure A. how aem v2 drives the temp gauge, IE if it changes the scale for the lights like modifry does, and B. how aem v2 temp scale in AEM software relates to original oem scale. v1 its close but not exact.
Steven622
Arizona Classifieds
Jun 28, 2015 03:42 PM
Picturepro
Aug 1, 2013 10:16 AM
CarbonYellowJ's
May 31, 2010 04:34 AM
sworks
Mar 8, 2010 06:14 AM
