Liquidgsr Laguna build thread
Old Mar 18, 2013 | 11:33 AM
  #431
liquidgsr's Avatar
I got it from a S2ki member....it was used.
Old Mar 19, 2013 | 03:12 PM
  #432
liquidgsr's Avatar
Well got bad news the clutch was installed wrong. But it's fine. They are going to have the machine shop check if the flywheel is true.
That's not the bad news.
The crank has play in it. It's moving back and forth. I have no idea how this happend since the car was never turned on. I don't know if the bottom end needs a rebuild not or what. They are dropping the oil pan tomorrow and going to see what needs to be done. I'm pretty much devastated and don't know how or why this happend.
Old Mar 19, 2013 | 06:43 PM
  #433
miguel329's Avatar
you are'nt having any luck man!
Old Mar 19, 2013 | 09:35 PM
  #434
bobbyrandolph440's Avatar
What was installed wrong on the set up ??? And thats very strange. Inless the clutch install shifted something in the bottom end
Old Mar 20, 2013 | 02:07 AM
  #435
Phill24's Avatar
i dont see how a clutch install can lead to u messing up ur bottom end especially if u never started the car...u should pm the person u bought the setup from and find out why they decided to sell
Old Mar 20, 2013 | 04:10 AM
  #436
liquidgsr's Avatar
I got it from BrockB. He pulled it out since he went with a V160 swap. Im not sure how this happend or if it was something that had happend before. Im not sure what its going to take to fix this problem either.
The only thing installed wrong on the clutch was what Kyle mentioned. The spacer discs were not aligned correctly like he showed.
Old Mar 20, 2013 | 05:26 AM
  #437
passmans2kny's Avatar
dam that sucks, hope the bottom end is ok
Old Mar 20, 2013 | 05:28 AM
  #438
camuman's Avatar
thrust washers could be trashed.
Old Mar 20, 2013 | 05:29 AM
  #439
liquidgsr's Avatar
If that is the case would I need a new shortblock?
Old Mar 20, 2013 | 07:31 AM
  #440
redboost10's Avatar
not a new short block but definitely will need to disassemble and replace thrust washer and check out the crank. sorry man, keep with it
