Liquidgsr Laguna build thread
Old Apr 15, 2013 | 08:30 AM
  #611
wy2slow_z's Avatar
My second time around. I just kept tightening it. Its on there damn tight now. I feel fairly confident it won't happen again. The adaptor bolt will bottom out then the block side will tighten further giving you a snug fit.
Old Apr 15, 2013 | 08:48 AM
  #612
herecomesboost's Avatar
Originally Posted by redboost10
Is that what bottoms out? I've seen old threads that say to shave the Honda fitting down, so I wasn't sure.
Shaving the Honda fitting would exacerbate the issue. If the Canton bolt is too long, it doesn't matter if you tighten it REALLY tight against the block, oil will still leak from the gasket like a sieve.
It will to a point. If the canton Bolt is too long (which many of them are by at least a few millimeters), you will bottom out. It would be REALLY tight on the engine block itself, but the adapter block will not be putting adequate pressure between the gasket/engine block.
Old Apr 15, 2013 | 09:00 AM
  #613
redboost10's Avatar
That's what everyone wasn't sure of: if the Honda bolt was bottoming out inside the canton OR if the canton bolt was bottoming out.
Thank you for the info
Old Apr 15, 2013 | 09:24 AM
  #614
You're welcome. For those who feel apprehensive about cutting the bolt, you could simply add a washer to create the necessary spacing. For example:
Canton bolt-->washer-->o-ring-->adapterBlock-->gasket-->engineBlock
(as opposed to the default configuration of Canton bolt-->o-ring-->adapterBlock-->gasket-->engineBlock)
Old Apr 15, 2013 | 09:25 AM
  #615
Oh yeah, apologies for the thread jack Nesar
Old Apr 15, 2013 | 09:43 AM
  #616
liquidgsr's Avatar
No that's a good point. Thanks for info Kyle. I will tell the shop to do that.
Wish I thought of that before this happend. Blah.
Old Apr 15, 2013 | 11:38 AM
  #617
liquidgsr's Avatar
Bain said he is going to cut the bolt down on a lathe in class tonight. Heat wrap was fubard so I told them to replace it. This should fix the problems.
Old Apr 15, 2013 | 11:40 AM
  #618
Old Apr 15, 2013 | 11:51 AM
  #619
liquidgsr's Avatar
I hope there's no other problems I think they have checked everything.
Old Apr 15, 2013 | 11:54 AM
  #620
Yeah dude. Are you sure your name isn't Murphy?
