Looking for basemap!
Old Oct 29, 2008 | 01:56 PM
EK9MAX's Avatar
Default Looking for basemap!
so I bought a used setup from anothe rmember here.
gt35r
lovefab mini-me manifold/ downpipe
3"inline exhaust
3mm headgasket
1000c injectors
Does anybody hav ea basemap or something to get me started? I have a certified AEM tuner in town so i just wanna give him a little help. thanks.
Old Oct 29, 2008 | 05:53 PM
03silver2000's Avatar
good luck, most people are tight about their basemaps. BEcause they spend money to get their car tuned the dont just want to give it away.....
Jordan
Old Oct 30, 2008 | 05:17 AM
timg's Avatar
1012 or 1052?
Wideband o2?
Saturated or Peak and Hold injectors?
Resistor box?
MAP sensor?
Tim
Old Oct 30, 2008 | 05:48 PM
EK9MAX's Avatar
Originally Posted by timg,Oct 30 2008, 05:17 AM
1012 or 1052?
Wideband o2?
Resistor box?
MAP sensor?
Tim
1052
gonna add a uego widband controller
peak hold injectors Rc 1000cc
resistor box
3bar gm map sensor
Old Nov 1, 2008 | 08:15 AM
timg's Avatar
PM me with your e-mail address and I'll send you a file which should get you close.
Tim
Old Nov 2, 2008 | 01:19 PM
I would like a basemap also ! ha my setup is 1052uego
with 3mm headgasket
precision 880 cc injectors with resistors
walbro 255
omni power map sensor... I have the calibrations for this I could enter the parameters for this
Thanks Jordan
Old Oct 16, 2010 | 02:40 PM
Tobisenpai's Avatar
I don't get it... how come everybody has map bar sensors? because on the AEM POWER forum it says that if you don't boost over 11psi you don't need a map bar sensor. are you guys planning to run more psi? much help would be appreciated because i am about to start putting a turbo in and i also need a base map for
t3/t4 turbonetics
precision 1000 injector with resister
walbro 255
with a aem 1012..
if you could get to me with some help it would be musch appreciated
Old Oct 16, 2010 | 03:19 PM
broke 20's Avatar
^^use the search button before you bring up an irrelevant question to the thread topic...two years after the last post. contact your tuner, they can help you with a base map
Old Oct 16, 2010 | 04:25 PM
Tobisenpai's Avatar
omg i didnt even look at the date ooops
4x4 freak
Jan 31, 2015 09:54 AM
r5turbo
May 19, 2014 02:06 AM
EK9MAX
Oct 21, 2009 10:14 PM
Ek_Jak
Aug 14, 2009 04:33 PM
ce127
Mar 9, 2007 07:05 PM
