looking for recommendation on fast spool turbo
Old Jan 30, 2018 | 07:33 PM
  #21
nguyen365's Avatar
Originally Posted by KV_Turbo
what are you running at for a/r, .71 or.82?
.82 hotside.
Man I haven't seen anyone go gtx28 yet that's an instant spool turbo. It's a decent sized turbo not like those small ones on the gtis, cruz, optima sxl, . They got them baby turbos lol..
But honestly to save the most money u should go with smaller hotside like .71? Gt3571?
Old Mar 1, 2018 | 09:38 AM
  #22
nguyen365's Avatar
Originally Posted by hatrickstu
You are missing the point completely. With a properly sized turbo you should have a much better overall powerband. My car NA and then with a turbo...
Mid range is significantly improved. That is with a turbo that is probably a little too oversized as well, you can make a ton more power down low/mid with a slightly smaller one. Again, why would you brag about an NA power band on a turbo car lol?
I ended up with 530whp at 19psi when retuned. My exhaust manifold was leaking before since the manifold Bolts weren't doing their job. Crazy power on full e85. I just run 91 and 5 gallons of e85 now.
Old Mar 4, 2018 | 02:16 PM
  #23
hatrickstu's Avatar
I apologize, but what does that have to do with what we are talking about?
Old Mar 4, 2018 | 03:48 PM
  #24
nguyen365's Avatar
Absolutely nothing
Old Mar 4, 2018 | 08:25 PM
  #25
MARK AUS S2K's Avatar
I am about to get my car back from the Tuners, I chose a GTX3076R with 1.01ar hotside. I wanted the spool to be slightly laggy then a rocket ship of boost to redline because let's face it that is what makes a car feel fast.
Old Mar 5, 2018 | 07:26 AM
  #26
nguyen365's Avatar
Nice widow Maker old turbo Porsche feel?
Old Mar 5, 2018 | 11:47 AM
  #27
nguyen365's Avatar
Originally Posted by spdracerut
Good question on what your current A/R turbine housing size is. My go-to is 0.82 A/R. The 1.06 is too big and costing you ~200-300rpm of spool. But I would still drop down to the GTX3071R in the 0.82 A/R turbine housing.
G-series is a badass turbo, but would also require a change to the turbo kit setup as the G-series uses a v-band inlet on the turbine housing. The GTX3071R would be nearly a drop-in replacement with the only difference being a slight difference in compressor housing outlet location. But that can easily be taken up by the flex in the IC piping. The G-series is really a motorsport turbo too, so the extra cost may not be worth it for a primarily street driven car. Well, unless one must have the absolute best
+1
DFWs2k
Oct 22, 2011 10:50 AM
skandal57
Oct 6, 2010 06:30 PM
pdexta
Jan 24, 2008 09:17 PM
nrgetik
Sep 13, 2006 10:40 PM
AndyDoh
Aug 20, 2003 07:28 AM
