lost on serial gauges
Old Nov 5, 2009 | 02:35 PM
Little_AP1_S2K's Avatar
also i got this figered out but now how do i hook up the wideband to the 1052u? if stock ecu wiring harness fits in the 1052u were does the wideband hardness plug?
Old Nov 5, 2009 | 09:25 PM
soulicious's Avatar
On my 1052U, the wideband plugs into the opposite side (180 degrees from the ECU plug) of the EMS.
Old Nov 5, 2009 | 11:10 PM
Druz's Avatar
Originally Posted by TRBOKEV,Nov 5 2009, 05:38 PM
One add a port for each gauge correct?
I'm not looking forward to programming these.
Just use one add-a-fuse. You only need to tap one 12v source for both gauges.
Or if you are not using the spare switched slot on your fuse box, you can use that and not need the add-a-fuse. Can't remember if the gauges come with a fuse built in though.
RAIN H8R
Jul 5, 2011 08:49 PM
skool u
May 29, 2010 08:36 AM
ian_6301
Car Talk - Non S2000
May 11, 2008 11:20 AM
lotus7racer
Oct 2, 2007 01:51 PM
krazyguy316
Feb 20, 2007 08:36 AM
