Lovefab or Comptech for MY04...?
Old May 19, 2005 | 05:31 AM
  #41
RZFD's Avatar
[QUOTE=Bo_Vien,May 19 2005, 01:18 AM] Sorry but I have a stupid question now.
Old May 19, 2005 | 08:11 AM
  #42
xviper's Avatar
[QUOTE=Bo_Vien,May 19 2005, 12:18 AM] Sorry but I have a stupid question now.
Old May 19, 2005 | 10:04 AM
  #43
Bo_Vien's Avatar
Xviper, thanks for the taking the time to explain all of that. To make sure I understand this, what you're saying is that at partial throttle at 4000 rpms (ie. cruising on the highway), there would be low positive pressure within the manfold, regardless of a S/C or a turbo. In other words, engine wear would approximately be the same under this condition. Now, under WOT conditions at 4000 rpms, the turbo would create more positive pressure than a S/C would. Engine wear would be greater for the turbo in this case. Did I understand that correctly?
Old May 19, 2005 | 12:35 PM
  #44
xviper's Avatar
Actually, at 4000 rpm cruising with either F.I., you would have manifold vacuum (negative pressure).
The rest of it, I think you've got a pretty grasp of things.
When it comes to "wear", certainly I believe that although you would have more wear in the turbo (WOT) compared to the S/C, that wear may not be significant (or measureable) based on the fact that this engine is so well built and so well lubricated (except maybe for the earlier models with the 2-hole oiljet bolts). Unless you plan to run F.I. for 70K, 80K, 90K or 100,000 miles, it might not be worth worrying about the difference between the two.
Old May 20, 2005 | 03:38 PM
  #45
honda9krpm's Avatar
Originally Posted by RT,May 14 2005, 03:03 PM
Sooooo how many people here have had first hand experience with both an SC and a turbo on their S2000 (not at the same time )?
Yes I have and I think I have taken both systems almost to the extreme.
The turbo is way better than the sc in many aspects of FI. It's best to keep the car NA or take the full plunge and go turbo. The SC was just a little bridge that left me unsatisfied and endless desire for more power in the midrange.
Old May 21, 2005 | 05:24 AM
  #46
itsallforyou's Avatar
Originally Posted by kane.s2k,May 14 2005, 09:32 PM
Actually, it has nothing to do with what you're assuming. Those cars make about 2000whp which isn't easy to do using turbo's and it's just easier to use a blower.
Not that it matters, but top fuel dragsters are making 5000+ hp.
Little_AP1_S2K
Feb 4, 2010 04:24 PM
cbrguy7
Feb 5, 2008 05:00 PM
integras2000
Jun 17, 2006 10:06 AM
blackfx35
May 16, 2005 05:11 PM
Fanman
Dec 15, 2003 07:14 AM
