Low boost. Altitude?
Old Aug 19, 2014 | 12:10 AM
EK9MAX's Avatar
Default Low boost. Altitude?
Finally did some data logging today.
Set my boost guage for peak/hold.
3rd gear pull 10 psi
3rd gear pull 11.5psi
4th gear pull 11.8psi
I'm at 3700elevation. Running a 3.4"pulley on an ap2 with novi 1200 blower.
the SOS site says I should be in the 13-14 psi range. However I hear that they are conservative and some people are seeing a couple psi higher than the SOS website
Old Aug 19, 2014 | 12:39 AM
s2k manic's Avatar
are you air to air or air to water intercooled? air to air drops a minimum of 2psi and up to 4-5psi if there are too many turns in the piping. you loose boost with altitude as we are belt driven where a turbo would spin higher and compensate to a point.
Old Aug 19, 2014 | 02:45 AM
leoxle's Avatar
SOS website says 3.4" on a 1200 should be 14.5-15.5 psi, although I know those numbers are to be taken with a grain of salt.
Old Aug 19, 2014 | 03:15 AM
timg's Avatar
3700 ft is ~ 12.7 psia versus 14.7 psia or so at sea level.
At 3700 ft, 11.8 psig of boost means a pressure ratio of 1.93.
At sea level, 14 psig of boost means a pressure ratio of 1.95.
Your pressure ratio is right where it should be given your pulley size. I suspect that if you travel to sea level, you'll find your boost level to peak between 13-14 psig.
Tim
Old Aug 19, 2014 | 04:47 AM
Moddiction's Avatar
Former Sponsor
Larger exhaust will also reduce boost levels.
Old Aug 19, 2014 | 05:39 AM
EK9MAX's Avatar
Race heat exchanger.
Stock car/exhaust
Old Aug 19, 2014 | 07:18 AM
EK9MAX's Avatar
Also, I don't plan on leaving the city with this car. Is it safe just to get a smaller pulley to up the boost safely? Say a 3.2" or 3"?
Old Aug 19, 2014 | 09:39 PM
EK9MAX's Avatar
The datalogs from my hondata read even lower.
8-9psi
4bar hondata map sensor...... This is depressing
EOE
Mar 16, 2012 09:37 PM
freshs2k
Jan 12, 2010 06:34 AM
2gr84u
Sep 8, 2008 07:06 AM
synapse
Sep 19, 2007 04:15 PM
Hobb
Jul 27, 2002 09:30 PM
