low compression pistons in a f20c
Old Sep 15, 2008 | 12:58 AM
fadiss2k's Avatar
Default low compression pistons in a f20c
Ok, i was just wondering last night...someone a while back posted something about using H22 pistons in a f20 bc they both have 87mm bores etc etc. That along with other thing(i dont remember what) makes a 2.4L. So in theory h22 pistons work in a f20 motor. Now Mahle Racing makes a FRM friendly low compression piston for the h22. So could i buy the H22 Mahle 9:1 pistons and use them in the F20 so that i dont have to resleeve the f20 block to get low compression pistons?
Thanks
Fadi
Old Sep 15, 2008 | 04:36 AM
briggle's Avatar
No, They will not yield a 9:1 CR. The compression height of the H22 piston is less than the compression height of the F20C1 piston. This affects the Volume at Top Dead Center, VTDC, and thus has an affect on the compression ratio (CR). You would have to run the numbers on it, due to the difference in compression height, it should cause the CR to change, of course the stroke is different on the H22 too so it may be wash. The only purpose to using the H22 pistons was the correct compression height and rod length for the use of the K24 crankshaft. If you are to reuse the F20C1 crank, than I believe that other companies may make a replacement piston for the FRM sleeves. If you use the K24 crank, the CR will be greatly inflated due to the increased stroke. In this case you would most likely need to specify your piston dish, in cc's, to a piston manufacturer to ensure the proper CR. Mine was a -13.5 cc H22 piston, with a stock head gasket, K24 crank, and with the cc's from my head yielded a 9.3:1 CR. But each application will be different due to head milling, porting and reworking of the combustion chamber etc...
Old Sep 15, 2008 | 08:07 AM
2big4aS2000's Avatar
i have a source for low compression pistons that are FRM Friendly - infact we helped develope them and spec using honda rings!
Old Sep 15, 2008 | 04:07 PM
AusS2000's Avatar
Do tell!
Old Sep 16, 2008 | 12:41 PM
c_me_go's Avatar
is that the same pistons you guys gave me that took a year and half to get??
Old Sep 16, 2008 | 12:43 PM
passmans2kny's Avatar
just do the head gasket, way cheaper
Old Sep 16, 2008 | 12:48 PM
no Rod - same company but your pistons are ment for much higher boost and a sleeved block.
Old Sep 16, 2008 | 12:59 PM
c_me_go's Avatar
ok.. just checking.. thanks for the update
Old Sep 18, 2008 | 11:28 PM
fadiss2k's Avatar
any update???
Old Sep 19, 2008 | 05:03 AM
i can not post in here - it will be delete, they will consider it a commercial post, sorry . I will get those pictures to you soon.
beaudin223
Nov 4, 2016 01:18 PM
jaydiii
Mar 17, 2014 02:43 PM
fatjoe10
Dec 3, 2009 07:25 AM
Yels2000
Nov 30, 2007 10:11 AM
