lower vtec pt. on AP1 vortech V2 on AEM v2?
I was reading up here today but couldn't quickly find an answer to this.
Can I get the vtec engagement lowered to about 3700 instead of the normal 6000 on my AP1 vortech v2 on AEM v2 EMS(other mods listed in my signature)?? I want to say its only possible on the AP2???
Thoughts? Enlightenment? Criticism?
Can I get the vtech engagement lowered to about 3700 instead of the normal 6000 on my AP1 vortech v2 on AEM v2 EMS(other mods listed in my signature)?? I want to say its only possible on the AP2???
Mines set around 4200
Thanks man. I'm gearing up for a retune with my Reichard Racing 3.4" pulley(400HP here I come!). I'll get them to lower vtec then.
Thanks again.
Originally Posted by joes sled 2000' timestamp='1412714542' post='23360317
Running the stock exhaust and cat with vtec set at 4k with my Vortech setup . Nice smooth power delivery . You don't feel the vtec switchover though .
Originally Posted by VTEC2000' timestamp='1412730923' post='23360674
[quote name='joes sled 2000' timestamp='1412714542' post='23360317']
[/quote]
Yeah the cat is a real choke point on this car. The reason why you’re able to drop it lower then the typical 5.3k rpm is because you’re forcing it with the supercharger. You would gain a considerable amount of efficiency without it. Yeah about 15whp across the rpm band and an even lower vtec engagement. Mine was set to 3400rpm at 17psi on the supercharger. Keep in mind your cat will break/melt and clog your exhaust system eventually. When it does you will notice a pretty dramatic power loss. You don’t want to drive around with a failed cat for long, as it will increase your combustion temps dramatically and cause your engine to work hard, detonation usually ensues.
