lowering boost on greddy profec B spec 2
Old May 4, 2009 | 06:06 PM
sbrodacz's Avatar
Banned
Default lowering boost on greddy profec B spec 2
I want to lower the boost on my car until I can figure out the ignition problem. I have the greddy profec b spec 2 boost controller. Can I just lower the boost or do I have to adjust the again and everything else?
Old May 5, 2009 | 03:36 PM
RichV's Avatar
Can't lower the boost with a boost controller, any boost controller. It won't go any lower than what the wastegate spring is set at. Don't know what wastegate you are running, so not sure what spring is in there.
Boost controllers only go one way, up.
Old May 5, 2009 | 03:42 PM
Chris_Lum's Avatar
Sorry i forgot to respond to your PM.
yes you can only raise boost from base boost. however, if you are already set at higher boost, for example 10psi on the greddy kit, you can lower it back down, just can't go lower than base (the set wastegate spring).
Old May 5, 2009 | 04:25 PM
Revenge's Avatar
Your boosting over 20psi so you should be able to lower the boost.
Old May 5, 2009 | 09:17 PM
sbrodacz's Avatar
Banned
^ I know I can lower the boost just wasn't sure if I had to adjust everything else on the controller. It's really annoying how you can't just turn it to a specific psi and it's a percentage. I messed around with it today and not it's running like crap. I guess it's going to take a lot of trail and error to get it to where it needs to be.
Old May 6, 2009 | 04:42 AM
RichV's Avatar
I'm sorry, I didn't realize you were 20+psi boost. Why not just cut the boost controller to the "off" position. There should be a setting that lets you bypass the boost controller and just run off of the preset wastegate spring. My truboost lets me run two different boost settings or off all together. The gauge isn't off, but the boost solenoid is off so you just run off of the wastegate. I am sure the Profec B has a similar feature. That way you don't have to mess with all of your boost settings.
Just an idea
Old May 10, 2009 | 07:42 AM
sbrodacz's Avatar
Banned
Issue's solved. Thanks guys.
Old May 10, 2009 | 12:49 PM
Spec_Ops2087's Avatar
Just an idea
profec spec b works the same way
ryiin2
Jan 5, 2018 05:14 PM
blueap2
Aug 26, 2009 06:56 PM
mr_grand_prix
Dec 21, 2007 04:46 PM
Spec_Ops2087
May 5, 2007 08:57 AM
2QYK4U
Jan 27, 2007 08:22 AM
