mac boost solenoid question ?
Old Sep 30, 2012 | 07:12 PM
S2KCHRIS305's Avatar
imma relocate it to the drivers side tomorrow . does it matter how long the vacuum lines are going from the turbo to the selonoid ?
Old Sep 30, 2012 | 07:23 PM
99SH's Avatar
Keep them as short as possible. I have mine no longer than 1 foot each way.
The fact that your solenoid works cold, but not when hot suggests to me that the length of your lines aren't the culprit.
Old Sep 30, 2012 | 10:27 PM
riceball777's Avatar
that location than you have pictured looks great to me. That location does not get that hot at all. I say you problems are else where. Make sure the wireing and vaccum lines is good and not pinched somewhere. Or maybe the mac solenoid is going out.
Old Oct 1, 2012 | 05:50 AM
Can some of you guys show me some pics of where you guys have your solenoids mounted?
Old Oct 1, 2012 | 05:53 AM
Im asking for the length of the lines , so I know how far I can relocate it
Old Oct 1, 2012 | 06:18 AM
sata3000's Avatar
I have a manual boost controller right now bc my mac took a poop.. but this is where mine was.. I would only hit low boost when my mac went bad...
:edit: can you all see my pic? bc i can't
Old Oct 1, 2012 | 08:14 AM
yess i can see your pic , that location seems better than mine , the fans are throwing hot air at mine, does anyone elses seem to get burning hot ? i tried it again this morning and the whole way to school it was fine hitting full boost , on the way back home once i got traffic and like a hour drive back home it= stopped working again , popped the hood when i got home n burning again , i wanna relocate it to the intake manifold side but now i hear its bad to have vacumm lines that long .
Old Oct 1, 2012 | 09:08 AM
99SH's Avatar
Can you elaborate on how you have configured your MAC solenoid to operate? E.g. when it kicks in & out
On the surface it seems like you're running the solenoid on continuous duty which is making it over-heat. Has the MAC ever worked successfully when you initially bought & installed it?
Old Oct 1, 2012 | 09:39 AM
Im not sure how its configured my tuner did all the configuration, its wired to my aem version 2 and to power under the dash, where it turns on with ignition, when I first wired it, I wired it straight to the battery for to have it installed quick to tune my car that day, I left it to the battery for about 3 months before I decided to change the power source to under the dash because it was killing my battery, maybe I fried it during that time n its not working right. I still think its a heat issue though ,
Old Oct 1, 2012 | 10:14 AM
robotvoice's Avatar
The MAC site suggests a max temperature range of about 120F for most of their solenoids. Maybe take some temperature readings around the area you have your solenoid mounted to see if you're breaking that range or not.
