mac boost solenoid question ?
Old Oct 1, 2012 | 03:06 PM
  #31
S2KCHRIS305's Avatar
Originally Posted by Sergei
My MAC got hot just the way you describe it when I had it wired up incorrectly. Double check that you have it running to the correct pin on the D connector. If your wiring is correct, I'd say your solenoid is just bad and is having some sort of short.
do you have the aem connector diagram of where the pin is supposed to be? i wanna check that, even though im pretty sure i have it on the right pin . imma check everything over , i really wanna find a way to relocate to the intake manifold side
Old Oct 1, 2012 | 03:22 PM
  #32
99SH's Avatar
D16
Old Oct 1, 2012 | 03:25 PM
  #33
thanks so much 99sh imma double check that , but wouldnt it not work at all if it was on the wrong pin ?
Old Oct 1, 2012 | 03:41 PM
  #34
99SH's Avatar
Correct. I wouldn't think its your wiring. Unless you have something intermittent which is breaking open at HOT.
Out of curiosity, what is your wastegate spring and what are you limiting boost to?
Old Oct 1, 2012 | 04:01 PM
  #35
My greddy turbo is internal watergate n my,boost is limited to 18psi if it creeps but its set n tuned at 13.5psi
Old Oct 2, 2012 | 05:15 AM
  #36
nuk1ear's Avatar
it def shouldnt get anywhere around 120F lol. Honestly, ive never had an issue with my solenoid being too hot to touch, and the length of your vac lines isnt actually a worry, unless theyre like 10m long each, pressure isnt like flowing water so length has next to no effect on it, just use thin line. But it does reduce the amount of tube that can break/cut/jam in places
I would think faulty solenoid or wiring. Check the wiring first, and resistance in the solenoid if you have any specs to go by
Old Oct 4, 2012 | 03:26 PM
  #37
**UPDATE** i relocated my solenoid to a cooler location and rewired it , tested it out n it was still extremely hot ,it seems like the solenoid is getting that hot on its own and not getting hot by the area its in, it must be a faulty solenoid
Old Oct 4, 2012 | 04:15 PM
  #38
camuman's Avatar
That would explain it failing. Bummer
Old Oct 7, 2012 | 08:54 AM
  #39
didnt wanna make a new thread for this question so il ask on here , anyone running the AEM solenoid ? are they any good ? reliable? thinking about going with the AEM solenoid, what you guys think
Old Oct 7, 2012 | 08:59 AM
  #40
camuman's Avatar
I'd just buy another Mac of eBay.
