MADjdm's Turbo Build
Old Apr 25, 2009 | 11:02 AM
MADjdm's Avatar
Default MADjdm's Turbo Build
Hello S2ki,
This thread will be used to document the progression of my ongoing turbo build from start to finish on my 2002 s2000. Prior to purchasing the car in 2004, I knew that my long term goal was to eventually go turbo. The S was daily driven for four years, but since I have relocated and no longer need a vehicle, I decided that it was a good time to take on the endeavor.
I plan on allocating one years time to accumulate all neccesary parts and complete installation and tuning. I will be maintaining the motors stock compression ratio and am hoping to achieve 450 rwhp with a tune by Jeff Evans.
EDIT 7/15: I will NOT be keeping the motors stock CR and am now hoping to achieve 525-540 rwhp on 93 octane
Parts that I have purchased:
Garrett GT3076r .82 W/ TiAL V-Band Housing, 90 Degree welded Elbow
TiAL 44 mm V-Band WG (7 PSI Spring)
PFAB Equal Length V-Band Manifold
PFAB 3" V-Band Downpipe
PFAB V-Band Dumptube
ACT Street Disc/Heavy Duty PP w/ OEM TOB and Fluids
All neccesary V-Bands
PFAB Intercooler Piping
PFAB Stage 2 Intercooler
PFAB Intake Pipe
HKS SSQ BOV Matte
Full Race Oil/Coolant fittings
Walbro 255
Battery Relocation Kit
Ti Heat wrap, Blanket & Gold Relective Sheet
SOS 3 Bar Map
SOS Pod
ARP Manifold Studs
Resonated single 3"
IP EGR block off
AEM EMS (U-series)
AEM Serial Gauge x2
AEM Boost Control Solenoid
Bosch Injector Dynamics 1000cc W/ Clips
OEM Headstuds
AP2 Retainers
OEM Valve Seals
IP 3mm Headgasket
Oil/Coolant lines
Modifications:
Battery Reloc.
Fusebox Reloc.
AC Removal
Air Pump removal
Supra PCV
I've probably left a few things out, but will be continually updating my progress.
Parts that have arrived thus far....
What could be in here?
V-Bands Galore
In all her glory....
Wastegate...
ACT Clutch
Waiting for Boost
Thanks for taking a look
Old Apr 25, 2009 | 01:26 PM
myclue's Avatar
Gold Member
my old ce28s?!
Old Apr 25, 2009 | 02:10 PM
MADjdm's Avatar
Originally Posted by myclue,Apr 25 2009, 01:26 PM
my old ce28s?!
Yep that's them! I'll most likely be selling them and going back to oem though must have put under 500 miles on them since I picked them up
Old Apr 25, 2009 | 02:24 PM
Enthralled's Avatar
nice!! same as what I'm shooting for. when do you think you will be completed with this project?
Old Apr 25, 2009 | 03:59 PM
rob!'s Avatar
nice build up so far. If you lose motivation let me know ill give you a ride in mine. Metroooo
Old Apr 25, 2009 | 04:49 PM
leo520's Avatar
how much is going to get that kinda system?
Old Apr 25, 2009 | 07:46 PM
Enthralled's Avatar
Garrett GT3076r .82 W/ TiAL V-Band Housing, 90 Degree welded Elbow (Courtesy of Honeywell International)
TiAL 44 mm V-Band WG (10.1 PSI Spring)
ACT Street Disc and Heavy Duty PP
Parts that I will be purchasing:
Intercooler (Unknown)
TiAL 50mm BOV
ARP Manifold Studs
AEM EMS
AEM UEGO
Walbro 255
Exhaust (Unknown)
Boost and Oil Pressure Gauges (Defi or AEM Serial)
Sticky Rubber (Unknown)
you forgot an FPR.
Old Apr 25, 2009 | 07:53 PM
Sellout's Avatar
Originally Posted by Enthralled,Apr 25 2009, 07:46 PM
you forgot an FPR.
Can't use the stock FPR?
Old Apr 25, 2009 | 09:03 PM
Spec_Ops2087's Avatar
stock works perfectly fine
Old Apr 25, 2009 | 09:32 PM
Enthralled's Avatar
correct me if I'm wrong, but I thought a static FPR would be recommended for an EMS application.....or atleast this is what my research has lead me to believe. take it easy on me, i'm still doing research on turbo applications with EMS.
