main harness removal question
Old Sep 21, 2009 | 11:28 AM
juntuned's Avatar
Default main harness removal question
In removing the main harness I have all the wires draped over the passenger side.
I cannot fully remove the harness because this metal ring around one of the plugs is bigger than the hole.
I know the harness has to come out this way because the ABS plug will not fit through the drivers side hole either.
so what did you guys do that have removed the main harness? That metal ring does not look very easy to cut through
Wiring will start on the removal of secondary air and a few other things if I can figure how to get the freaking thing out.
Old Sep 21, 2009 | 12:32 PM
Asura's Avatar
Disconnect the 3 plugs from the ECU and pull the harness through the firewall.
Old Sep 21, 2009 | 02:47 PM
jefferyg32's Avatar
Pop the 2 pins out and re-pin them back in after you pull it through?
Old Sep 21, 2009 | 04:55 PM
juntuned's Avatar
This IS NOT the ENGINE harness that clips into the ECU... that one comes out easy.
I dont know what the proper term for this harness is, but Im calling it the MAIN harness. Its the one with all the secondary air clips.
Nobody has pulled this or what?... uggghhh
Old Sep 22, 2009 | 10:21 AM
Tech7427's Avatar
de pin the connector and pull it through.
Old Sep 22, 2009 | 10:30 AM
Momentum's Avatar
Momentum's Avatar
whoops beat me to it
Wydget
Feb 5, 2012 12:15 PM
sapone
Jun 28, 2011 03:07 PM
solomon
Jul 28, 2006 09:56 AM
spapdx
Mar 21, 2003 11:07 PM
