Maintenance on Comptech charger?
Old May 9, 2007 | 01:23 PM
M32's Avatar
M32
Default Maintenance on Comptech charger?
I just picked up an comptech sc s2000 and am wondering if there are any maintenance things I need to do. I read I need to oil it or something but if that's the case, I don't have the slightest idea where to oil. Anyone help?
The car has been sitting in a garage for the past 6 months (until I drove it home) so I want to make sure everything is good to go. Thanks everyone
Old May 10, 2007 | 01:51 PM
M32's Avatar
M32
anyone?
Old May 11, 2007 | 12:24 AM
SIIK2NR's Avatar
The snail is oil fed through a feed line.
Check the belt for tension and wear. Adjust as necessary.
Check the fittings for tightness especially on the mounting bracket and around the bushings. Additionally the Vtec selenoid.
Check the fitting for the oil return line to the oil tank and to the blower for leaks.
Check the fuel return line for leaks.
Check the vaccum hoses for cracks, leaks, cuts or disconnects.
Check the Air filter for cleanliness.
for starters.............
Tim
Old May 11, 2007 | 07:53 AM
73Zero's Avatar
[QUOTE=SIIK2NR,May 11 2007, 12:24 AM] The snail is oil fed through a feed line.
Old May 11, 2007 | 07:56 AM
M32's Avatar
M32
Thanks for the tips guys. I also called Nate@comptech. Very nice fella
Edwin
Old May 11, 2007 | 08:07 AM
pdexta's Avatar
Do you mind me asking what you paid for it and how many miles it has? I've been trying to sell mine, interested to know what you paid for a similar car. Thanks.
Old May 11, 2007 | 11:12 AM
elusiv's Avatar
Please search first next time, there is a thread entitled:
Comptech Maintenance
https://www.s2ki.com/forums/index.php?showtopic=397001
Old May 11, 2007 | 11:37 AM
M32's Avatar
M32
Sorry but I bought the car with the charger. I'm assuming with an aftercooler $3,300 - $3500?
Ediwn
SIIK2NR
Nov 11, 2005 01:48 PM
bigfishs
Apr 28, 2005 11:57 AM
Tuner 4
Nov 16, 2004 06:24 AM
SolReborn
Nov 4, 2004 01:23 PM
JamieS2K
May 19, 2003 09:28 PM
