Comptech Supercharger Sweating Oil?
Old Nov 10, 2004 | 02:29 PM
Tuner 4's Avatar
Default Comptech Supercharger Sweating Oil?
Is there anyone with the Comptech Supercharger who's charger is sweating oil from either thr front or rear or both?
I am seeing some oil residue in both the front & rear of the supercharger, I am wondering if this is so-called "normal"...
Thanks.
Old Nov 10, 2004 | 02:55 PM
xviper's Avatar
My Vortech does the same thing. It's not excessive so I'm not worried about it.
Old Nov 10, 2004 | 03:06 PM
Slows2k's Avatar
I always had a tiny amount in the SC inlet from the oiled air filter, but never any oil from the pulley side. I'd double check the oil isn't from the oil feed fitting.
If it gets excessive, the seal behind the pulley will have to be replaced, and the shaft inspected for wear. To much belt tension puts a side load on the bearings in the SC and can cause wear in the bearings, and the leak at the seal. I'd contact Paxton about repair costs.
Old Nov 10, 2004 | 08:52 PM
Tuner 4's Avatar
Shouldn't there be warranty from Comptech on the blower unit?
Old Nov 11, 2004 | 04:19 AM
Slows2k's Avatar
I'm sure that there is, But you'd have to contact Comptech about it.
Old Nov 16, 2004 | 06:24 AM
modifry's Avatar
Honorary Member
I agree that it doesn't sound right. If it's minimal (just enough to collect dirt) I wouldn't worry about it. But if it's a drip or seeps enough to re-create the seepage patch in a day or two I'd be calling Comptech.
I've got over 60k on the SC and the only oil seepage is around the bypass valve, which has always been there.
s2konroids
Aug 28, 2018 08:25 PM
SIIK2NR
Jun 16, 2015 08:19 AM
S20004ME_PDX
Mar 28, 2008 07:37 AM
BENJMNS
Sep 8, 2005 02:32 PM
gropos
Sep 29, 2004 02:52 PM
